Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - mild built t-350 shudders in gear..
Old 10-19-2011, 12:52 PM
J0386 J0386 is offline
Ok I took the module out of the distributor and had it tested and everything is fine even tried it with the vacuum advanced unhooked and it made no difference as for the fuel I cleaned out the fuel cell and put fresh gas in it and it still has the problem and for the psi when I tested it with the ebreak on and in gear and gave it a little gas to move a few feet the fuel psi dident change from 5 same as in idle and park
