mild cam for a 454 - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-23-2006, 04:57 AM
mild cam for a 454
I was wandering if you guys could suggest some mild cam grinds for 454. Something with a slight lope but still practical for daily use if need be. The one in the truck im interested in has more of a race grind.86silverado short wheel base. The guy said it has a 850 holley(headers) on it already and I think its still stock geared with stock converter.
Old 11-23-2006, 07:43 AM
Bumpstick's Avatar
Hammer and a torch
Here are a couple of great cams for what you wanting...
http://www.holley.com/00020.asp
http://www.holley.com/302A6LUN.asp
http://www.holley.com/60201.asp (my pick)
Old 11-23-2006, 07:55 AM
camshaft selection
edelbrock performer camshaft is the most mild i would install,works great in truck for pulling boats,cars,tractors.but since this is light truck(gvw) i would stick with one of the first two cams that were suggested by bumpstick in his reply.probably should install a towing converter to at least raise the stall up to 1500-1800,unless you have the 3.08 gears then leave the stock converter.
Old 11-23-2006, 01:05 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
I have an XE262 from Comp that idles smooth when hot, but a little lope when it first comes off the choke. It specs out to 218/224 on a 110 LSA. Ripping strong torque and I'm running big tires and 2.73 gears. Would be a perfect tow rig with an OD and 3.73s
Old 11-23-2006, 06:19 PM
Thanks for the suggestions guys. I've been listening to some sound clips. I'm thinking the 262voodoo would work for me with the addition of some gears.
60202 60202LK 262/268 219/227 .530"/.542" 112/108 Hyd/Hyd 1400-5800
60202 Description- Hydraulic: Mid-level performance street cam with excellent drivability. Exceptional replacement for "muscle car type cam" with automatic transmissions. Works well with stock type exhaust Manifolds and dual plane intake with mild 4 bbl carb. This is an Awesome 4X4 and performance marine cam where "Dry" exhaust is used. Improved valve springs and roller rockers recommended. Excellent in oval port engines.
'74 Corvette 454 dyno results- Comp Cam XE 274H questions Bob Turner Engine 12 05-19-2005 10:59 AM
Help Me Pic A Cam? Grant209 Engine 5 12-22-2003 05:05 PM
Roller Cam Help!!! Vsanthos Engine 13 10-31-2002 04:29 PM
Big Block chevy cam help deuce_454 Engine 4 05-20-2002 12:15 PM
question on cam & oil pump install chev 350 solowookie Engine 16 04-03-2002 04:25 PM
