Mileage out of Roloc discs - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-22-2013, 08:03 AM
Originally Posted by deadbodyman View Post
I believe there's only one size ,John... well..... that one and the thinner cut off wheel
Cool, I will look forward to them getting here. I ordered the 3M 01991 part number. I have been cutting down the Rolocs too for a long time. I have an old pair of snips who have been dedicated for that job. The 6 inch grinding discs also can be cut down very effectively.
I appreciate the replies.
John
  #17 (permalink)
Old 10-22-2013, 08:10 AM
deadbodyman's Avatar
Wiki Edits: 11
same here.dedicated tools are the way to go.... I have an old sissor type that wont cut anything but they cut the grinding discs perfectly...I also have an old pair of snips that I only use for rusty metal ..even old crappy tools have a use at my shop...
The Following User Says Thank You to deadbodyman For This Useful Post:
John long (10-22-2013)
  #18 (permalink)
Old 10-22-2013, 09:44 AM
I don't ever use them, but I believe there is a 1/4" cut off disc, we have them at work.
The Following User Says Thank You to MARTINSR For This Useful Post:
  #19 (permalink)
Old 10-22-2013, 10:08 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
as with any abrasive the life is determined mostly by the speed. the higher the speed the more heat. more heat will melt the glue and deteriorate the pad faster. i use low speed on everything including my buffer. da's , board sanders and grinders all work better at lower speed and the sand paper will last much longer .
The Following User Says Thank You to shine For This Useful Post:
  #20 (permalink)
Old 10-22-2013, 12:02 PM
I have to disagree in that the high speed is needed to CUT the weld, where as lower speed "Polishes" the weld and creates more heat than the cutting of the weld.
This where the cheapie tools fail, they can't maintain the speed because they have no torque. So you hit the weld with the disc and it slows down and polishes the weld!
It's like driving around a 69 Camaro with a hot little 350 in it. You THINK it it's fast and it handles well, until one day when someone lets you drive their ZO6 Vette, without that comparison you think your Camaro is fast and handles well.
  #21 (permalink)
Old 10-22-2013, 12:47 PM
shine's Avatar
SPI Thug
we'll have to agree to disagree. 90% of people run air tools 30-40 lbs higher than recommended. especially da sanders. they end up trashing one spot of the paper. i can get twice as much done at low speed with my angle grinder as opposed to running it wide open . heat just hardens steel and melts the glue and releases the abrasive .
  #22 (permalink)
Old 10-22-2013, 12:57 PM
I'm with you Shine on most sanders, but a grinding disc cutting welds I feel the higher speed with a quality disc cuts it so fast it has no time to heat up.
  #23 (permalink)
Old 10-22-2013, 01:44 PM
put up or shut up
I'd say 100-120 is common. Good point.
  #24 (permalink)
Old 10-22-2013, 01:51 PM
put up or shut up
I'd like to state that I use a lot of rolocs but I'm also not paying for them. That might change if I were paying for them. If that were the case, I'd probably already have a variable speed 4.5" grinder. I'll state it again, the angle grinders are great but it's simply too fast for the torque. If your surface isn't perfectly flat your high points will turn blue/brittle even if you are moving it around. I sure like how flap discs clean up welds but I'd rather take it a step slower knowing I've eliminated the chance of burning thru a high point or discoloring the metal and making it brittle. Just my opinion. Rolocs are costly but you have a lot more control with them. Shine is right about making the plastic melt on them. Sometimes that alone could be a reason to change out a roloc. I guess what I'm saying is each has it's own advantage and downer and it's just a matter of opinion from there.... it's just that my opinion is better.
  #25 (permalink)
Old 10-22-2013, 02:35 PM
shine's Avatar
SPI Thug
i'm old and i'm cheap . my 600 paper becomes 1000 .
  #26 (permalink)
Old 10-22-2013, 02:52 PM
You should try moving up thru to 3000 it would blow your mind! I did my stainless steel mouldings on the Gran Sport, repaired dent and metal finished them using 600-1000-1200-2000-3000 and they literally glistened like chrome needing no polish!
  #27 (permalink)
Old 10-22-2013, 03:08 PM
shine's Avatar
SPI Thug
i mean my worn out 600 gets used somewhere . i have been flamed more than once because i use every grit from 1000 to 3000 . i always said if there was no need for 2500 they would not make it.
  #28 (permalink)
Old 10-22-2013, 05:16 PM
Next time you do that, try color sanding the stainless just as you described but use WD40 as a color sand lubricant instead of water.
John
  #29 (permalink)
Old 10-23-2013, 06:26 AM
Wiki Edits: 11
X2,especially true with the grinding discs
  #30 (permalink)
Old 10-23-2013, 06:58 AM
Wiki Edits: 11
actually the1/4" grinding stone cuts twice as fast and lasts about four times longer than any grinding disc with nowhere near as much heat....Try the stone to grind down the welds and you'll never go back to the discs...I grind the welds just a little proud of flush then finish up with a disc till flush...unless we're talking perfect welds then you can skip all the grinding and just hit it quick with the disc...I'm talking about butt welds, but then theres plug welds which usually dont need any grinding at all,two completely different animals.I dont usually touch a plug weld unless its a real booger,if the car is ever in another accident and has to come apart I want the next guy to be able to see the welds so its not a nightmare to get apart...one thing I cant stand is seeing someone grinding and using filler on plug welds to hide a bad welding job...
3M Roloc, head porting tools IHRodder Garage - Tools 7 05-04-2010 08:04 PM
Shrinking discs??? suedespade Body - Exterior 16 09-17-2009 01:24 PM
moon discs black rat Hotrodding Basics 2 05-04-2008 08:39 PM
32 chevy discs 55 dude Suspension - Brakes - Steering 1 11-13-2006 05:11 PM
Discs EastCoastSBC Suspension - Brakes - Steering 1 03-17-2006 09:37 AM
