miling the heads? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2012, 06:29 PM
miling the heads?
Im working on my chevelle and am not pleased with the performance level. Its got 350 stock bottom end, Comp Cams 268(268/280, Lift .477/.480) Dart Iron Eagle heads 72cc, 165cc intake runners, 2.02x1.60 SS valves. edelbrock performer intake, Holley 650 DP, and hedman headers. The transmission is a turbo 350 with TCI shift kit and TCI breakaway 2200 torque converter. 3.55 gears out back. My concerns are the compression is way too low. It just seems like it doesnt set me back in my seat. It will break the tires loose but it dont pull very hard.My old weazy set up had 64cc heads and the smaller 1.94 valves. Would it be wise to mill the heads to get back down around 64cc again? Or is it cheaper to pawn the heads off and find some that are more fitting? Any input id appreciate guys. Thanks
Old 06-24-2012, 09:31 PM
No they're like flat tops with the valve reliefs cut in em.
Oppinions EQ lightening heads and EQ vortec heads eatonde Engine 16 02-18-2013 11:00 PM
305 heads or 350 heads on sbc 355 ryan v Engine 5 09-20-2012 10:21 AM
swapping 351W heads for 302 heads babell7738 Engine 10 01-21-2012 10:16 AM
SBC cylinder head bolts .. cast iron heads Vs Alum. heads terror385 Engine 3 08-04-2006 08:34 PM
Vortec heads or 1971 487x LT1 heads? speedfrk3 Engine 2 10-07-2002 04:12 PM
