If the intake was milled it would be smaller not larger right? I could see it being cut back but dont know why itwould be to tight a fit with the gaskets. Is the top and bottom of the intake plate have the same amount of gap.
Correct gaskets does the intake have egr. Have you tried a cheap thin gasket? Or trim the gaskets back at the bottom and see if they are fitting. Have the heads been angle milled or regular resufacing? Also was the block decked. Sometimes this will cause fitment issues. A die grinder will usally correct that issue. |
If the block has been decked and easy way to figure out how much needs to come off the bottom rail of the intake is to bolt the intake up with one gasket and then see what the difference is on the other side. Gaskets are .060 so if one gasket on one head give almost no room on the other side then you will need to take .030 off each side of the manifold and then normal gaskets will work.
This can also be done with a die grinder but maybe not the best way to handle the problem. Is this a victor manifold they do fit really tight. Newer manifolds have a wee bit more room since a lot of blocks are decked these days but the victor and other race style manifolds may still be really tight. If it almsot fits you can use thinner gaskets cometic i think will make any size you want but may result in a poor seal. I usally like to have felpro print o seals in the intake manifolds. |
machine formula.
A long time ago I had a chart that showed how much to mill, It depends on the machine work done to the heads and block, the percentages depended on the intake to head centerline angle vs the other dimensions centerlines, It is different % for different engines, that was done to get the bolt holes to line up. Then you needed to match the ports to the heads.
Buy anoth er one. rigging the milled one will cause other problems like oil coming out around the intake bolts.
Intake are usally cheap to have cut. I would either touch it up my self or have the right one cut to fit. Its usally only a little bit Of metal needs to come off so a file can complete the job if all else fails. |
the block is the same, I just replaced the cylinder heads,cam and intake. The engine only has @200mi since fresh rebuild. We are just upgrading the horsepower. I still don't understand why the intake sits soo high. After inspection, even the original intake that will bolt up) sits high, Could this be from the heads being angle milled? with no gasket, the intake sits flush on all 4 sides, and the threads are centered within the intake bolt holes.
| When would a intake need milled after milling cylinder heads and block SBC | eric32 | Engine | 4 | 12-04-2010 04:31 PM |
| Does this manifold need to be milled? | turchiac | Engine | 4 | 10-13-2010 07:31 PM |
| intake help?OFFenhauser low pro. ram intake manifold | 74chevyflat | Engine | 0 | 05-17-2006 07:49 PM |
| Can intake side of heads be milled? | brainsboy | Engine | 1 | 10-26-2005 03:31 PM |
| Intake manifold gaskets for alum. heads and intake | mustang66maniac | Engine | 6 | 02-20-2004 11:19 AM |
