Miller Dynasty 200 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2005, 01:51 PM
Miller Dynasty 200
Ok, I think I've made up my mind and I'm going to get the miller dynasty 200 TIG, i plan on building a water cooler. I've seen mixed things about it, on the miller site they have that weld calculator and it sayd i need 225-300amps for 1/4" steel welding, but then other people say that they weld that stuff all the time
I want it to weld sheet metal, aluminum and steel all probably less than 1/4" So this should work great right?!!
Anyone have one and can help me?
Thanks
Brendan
Old 10-12-2005, 02:43 PM
35WINDOW's Avatar
Last journal entry: Engine!
Well,
I'm certain you have done your homework, and I also considered the 200 Dynasty as well, but I purchased a Lincoln Pro Tig 185 and absolutely love it! I can weld up to 3/16" and it does a great job-
Craig
Old 10-12-2005, 03:04 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Dynasty
That is a great piece of equipment and should do you fine for years..as far as doing 1/4 in plate that may be pushing it a bit but with practice you can push a machine to its max and do a good job..
Just my take..
OMT
Old 10-12-2005, 04:16 PM
ronb's Avatar
should be fine with 220 single phase 60 amp breaker!
Old 10-12-2005, 04:26 PM
thanks for the replies, i also looked at the lincoln unit but it only goes down to 5 amps where the miller goes to 1 amp, i haven't tig welded before but i figure thats better, and they are about the same price anyways,
i can always weld thicker stuff with our bigger millermatic mig
Thanks
Brendan
Old 10-12-2005, 04:33 PM
ronb's Avatar
Thanks
Brendan
you will never see 1 - 5 amps of welding!
cam selection for sbc w/ efi and e-tec 200 heads? c10redneck Engine 0 07-18-2005 12:48 PM
Engine knock under 200 miles.... Sodflyer Engine 8 10-23-2004 07:42 AM
200 R4 capicity screamin340 Transmission - Rearend 0 04-15-2004 07:11 AM
200 MPH road warrior BillyJoe General Rodding Tech 16 01-07-2004 09:52 PM
THM 200, CBC 350 or TH 350???? 78novaman Transmission - Rearend 4 11-25-2002 02:34 PM
