Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Miller Econotig
Thread: Miller Econotig
Old 08-28-2012, 07:53 PM
Augusto's Avatar
Augusto Augusto is offline
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
you need to weld alum in AC mode, use the green dot non toriated electrode, most of the time you'll have to use almost full power, pedal to the metal to start melting the aluminun, then ease off the heat, you should practice, practice and practice, it takes some time but I'm sure you'll end up loving welding aluminum with the econotig. I found the dipping of the rod the hardest part, this is what makes the weld look good.
