The light will come on on most machines if the air pressure is low or no air pressure.. If you hook up the air to it, It should go off.. Some machines you have to turn them off then back on..Give that a try..
You can get the original Miller manual for that machine by downloading it free at Miller's site http://www.millerwelds.com/service/o...uals.php?model You'll need to enter the serial number of your machine and then scroll down thru the list below and highlight the Spectrum 500.
Be careful if you open it up. There are some high DC voltages present in plasma cutters that can light you up much more than the same level of AC voltage. |
Make sure the tip is in right.. That will also do it..
The best way would be to show up there with it,don't call,most of the time calling them they will say drop it off and we will look at,walking in the door with it will most likely get immediate results to at least try it out. |
| Recent Garage - Tools posts with photos |
