Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Milling the choke horn off a carb
Old 04-11-2005, 07:45 AM
Tech @ BG Tech @ BG is offline
Technical Support Barry Grant
CruisingRam,
IF you have one of the old Holley Dominators with the choke towers on it you should not remove them. Those carburetors actually flowed better due to having the stacks on them. They are also worth more to someone that actually needs them. If you need to remove them for clearance, you'd do better to sell the carburetor, and invest in a newer model.
