Milling the choke horn off a carb - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2005, 01:08 PM
New Member
I have a dominator I want to take the choke off of, and mill off the choke horn- anyone had this done? Was it by a carb shop or a machine shop?
Old 03-22-2005, 04:18 PM
Tazz
take the carb apart and do it yourself....
get a dremmal/sp? and a disc cutter and have at it then grind away the rest. Or call up a local speed shop and ask them to do it for you.
Tazz
Rat Rods Rule!
Old 04-07-2005, 07:21 AM
cuda66273's Avatar
Or sell the street Dominator and buy a King Demon, there's allot more to air flow than milling the choke horn. You'll see virtually no gain what so ever by just milling the choke horn off.
Old 04-07-2005, 01:19 PM
Last journal entry: PICTURE TEST
Carb
I personally would have a machine shop do it... but i have never seen a dominator with a choke horn on it before????? Can you post a picture of it????
Keith
Old 04-11-2005, 07:45 AM
Technical Support Barry Grant
CruisingRam,
IF you have one of the old Holley Dominators with the choke towers on it you should not remove them. Those carburetors actually flowed better due to having the stacks on them. They are also worth more to someone that actually needs them. If you need to remove them for clearance, you'd do better to sell the carburetor, and invest in a newer model.
Old 04-11-2005, 07:58 AM
Carb
BG,tech
So holley made a dominator with a choke horn???? Do you by any chance have a pic of it????
Keith
Old 04-11-2005, 08:18 AM
Keith,
They were done in the 60's. It's been 9 or 10 years since we've done any of them. I'll look to see if I have one laying around.
Old 04-11-2005, 08:47 AM
carb
Thanks, I never knew that... I guess this is the thing i learned today!!!
I wonder what there idea was behind that design???
Keith
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 04:36 PM
Adding choke to holley carb rnix999 Engine 0 06-14-2004 12:35 AM
Edelbrock Carb Choke wire problem rakundig Engine 2 01-25-2004 09:34 PM
I want to remove the choke horn cuda66 Engine 4 04-01-2003 08:37 PM
quadrajet carb with electric choke ace1 Engine 0 12-18-2002 07:56 PM
