Not sure on a amc head but on sbc heads the limit is the edge of the intake valve seat and or the spark plug boss. Wether the heads will be durable after that much machining is another story. Flat milling will get you so much chamber reduction, angle milling will get your more, but costs more.
You don't mill the intake to correct, you mill the intake joining face on the head. You may need to enlargen the intake bolt holes. Is there another amc cylinder head that has a smaller chamber volume you can start with? Shaving the heads by .042" will get you about 1/2 a ratio gain assuming the same head gasket. |
There are the dogleg heads that flow better with smaller combustion chambers, but then I will start getting into serious money that I don't have.
Do you have any idea about how much the ratio would be for shaving the head intake port face for a given amount of milling? |
the intake face milling correction ratio is based on the cylinder bank angle and the angle of the intake face.. I have the chart for this buried away somewhere. A qualified machinist will help you with this. I would look into angle milling your amc heads to get a significant net chamber volume reduction 11-12cc to get a whole compression ratio increase on your motor. A thinner head gasket helps too. Last edited by F-BIRD'88; 02-19-2010 at 05:20 PM. |
Its in the Knowledge Base on the bottom of the page,
http://www.hotrodders.com/kb/general-engine
Luv the smell of NITRO in the morning. |
Yeah, the main reason is people just don't know that an AMC 360 is hands down a better built engine than a run-of-the-mill 350 Chevy. The heads are closer to LS-1 heads, not the standard 350 heads, though they are run-of-the-mill AMC heads.
Seriously, the 360 has some faults the same way the SBC 350 and all other engines do, but it's as good as any in it's size, with the heads being some of the best standard production heads ever made, equal to the big three performance heads in most cases. There aren't as many parts available for AMCs, but the ones that are still available are the ones that work well. Decide on the rpm range you want and you don't have to wonder which of five or more will be best, you'll only have one or two choices -- but known to work well choices. The "dog-leg" heads were made from 1970-91. The early model heads have smaller chambers but were only made 70- mid 71. Those have a 51cc chamber and 9:1 compression on 2V engines, 10:1 on 4V. The 4V engine had a piston with a smaller dish, heads are the same. Mid-71-91 heads have a 58cc chamber and 8.5:1 compression with the same pistons as the 2V early engine. The head gasket compresses to about 0.042" (0.048" before compressing -- stock head gasket). With the stock 4.08" bore that's 9cc. So cutting the head 0.040" will reduce the chamber by 9cc, 0.020" by 4.5cc. Do the math and figure out what your compression ratio will be. Using the calculator at http://www.rbracing-rsr.com/compstaticcalc.html, I come up with a 0.32 increase in compression with a 0.020" cut (4cc chamber reduction), a 0.66 increase with a 0.040" cut (8cc reduction). My AMC books don't say how far you can cut the heads. 0.020" is safe, I don't know if 0.040" is or not -- talk to your machinist. With the 0.020" cut you come out with 8.78:1 compression, 0.040" = 9.12:1. The "291" heads (70-mid 71) are pricey because they increase compression by 0.5 points simply by swapping the heads. Other than chamber size they are identical to the later heads. They are generally referred to as "291" heads because the last three digits of the casting number are 291. Some call them "319" heads for the first three digits of the casting number. Valve sizes are the same for all 360 and 401 heads (heads are the same) -- 1.680 exhaust", 2.025" intake. The only real difference is the chamber size, but the price of the 291 heads has sky rocketed because some idiot in one of the rodding magazines stated that they were the "best" heads. They aren't. If you're building a mid 71+ AMC engine just buy the appropriate pistons to get the compression you want, don't waste money buying those heads! They are times when they would come in handy -- like upping compression on an already built engine, but otherwise they aren't worth the inflated prices. Even the performance book AMC printed in the early 70s states that the dog-leg head exhaust port flows "50% better" than the 66-69 343/390 rectangular port head, but someone was smoking something that day! The port is no more than 15% bigger. I know size isn't everything, but other than the "dog leg" the port shape is about the same as the earlier head. I seriously doubt flow increase is more than 20% at best. For flow numbers on the newer heads see http://theamcforum.com/forum/cylinde..._topic159.html. |
As it is, with a 58cc chamber, you'll need a 20cc dished piston to get a 9.45:1 CR. This is with a .042 head gasket thickness, zero deck, stock B&S, 4.125 head gasket bore diameter. Some info on OEM and aftermarket AMC heads: CLICK. |
Sorry I wasn't very clear. I'm bad about that. Thanks for the link.
I guess what I was getting at, is no milling is needed, just a smaller dish than the engine came with should get you all the CR you need. This won't help if you wanted to keep and use the original pistons, though. Good luck. |
If I had big bucks to spend, it would be easy just to get a pair of Edelbrock heads, but counting shipping that would be close to 2k I'm sure they are good heads, but money is tight. |
I'm sure that's not the only way to do it, but there aren't a lot of options with a thin wallet.
A standard bore 400 piston on the AMC rods bushed to fit SBC pins, block bored 0.045" and the deck cut 0.020" would work (piston down the hole ~ 0.020(?)- or offset grind the crank to make up the difference, etc.)- but at what cost? It all adds up! Anyway, keep us posted. |
| Milling 993 heads - help please! | Flightless Bird | Engine | 4 | 02-26-2005 10:38 AM |
| Is milling heads a good solution? | almega | Engine | 7 | 01-18-2005 09:20 AM |
| Heads | novatech | Engine | 10 | 01-17-2004 01:27 PM |
| Milling heads | mgof | Engine | 0 | 12-19-2003 01:14 PM |
