million dollar c4 question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2009, 09:05 PM
Long story, I have a 69 Mustang that I have owned since 1979. Back in 80 I blew the tranny and picked 1 up from a wrecker. Bolted in fine and worked except that the inspection plate from the original c4 does not fit. Started a rebuild back in 82, kids came along and the project sat in the garage for almost 30 years. Now the kids are gone and damned if I'm going to watch Oprah with the old lady. Soooo I've been chipping away at the old Stang and I had the tranny rebuilt with a shift kit and higher stall converter.Sorry to bore you all but I was wondering if there are different bell housings for a c4? I have a 302, and as I said this tranny worked but the inspection plate bolt pattern is 1/4 inch wider than what was on there before and one of the dogs ,backplate -tranny doesn't quite line up. Any experts out there? Thanks in advance.
Old 02-27-2009, 12:19 AM
aka Duke of URL
The C4 went through a redesign in 1970. You may have lucked out and got a later model. Any Assembly I.D. Tag Nos.?
Old 02-27-2009, 03:07 AM
Wiki Edits: 85
If the one from the wrecker bolted in, I don't see how you could have the issue you have with the cover. There was only one 302 bell housing on C4s in 1969 for case fill C4s behind 302s. Using any other bell housing would have meant flexplate problems and/or block plate problems and/or converter problems and/or mounting problems and/or clearance problems. Since you said it bolted right in, I assume that you had none of those problems. So, the only other alternative I can think of is that the plate you have was from something else and got mixed up sometime in the last 39 years.
Old 02-27-2009, 07:09 AM
No id tag ,already looked for one. Got the cover plate off of Ebay because I couldn't find the one that I had. Cover plate that I had off of the original posed the same problem I recall. I'll check to see if a later cover plate will work, thanks guys.
383 stroker 73monte Engine 13 05-11-2016 11:17 AM
supercharger.... 73monte Engine 16 07-24-2010 10:27 AM
C4 install question demitristewart Transmission - Rearend 4 09-20-2005 09:27 AM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 01:20 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 10:25 AM
