Milodon or FlowKooler water pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2013, 11:49 AM
Anyone have any input on these? I need a new water pump and I just can't choose between the two. I've done some research and the results are about even. I live in Florida and my car is a everyday driver so I need something really cool.
Thanks.
Old 04-10-2013, 12:03 PM
Irelands child's Avatar
I wouldn't use either. I would spend my hard earned bucks on a Stewarts
All you need is a Stage 1, but a Stage 2 is a comfort factor:
Ford: Stewart Components, Inc.
These are the guys that do many of the NASCAR water pumps
Irelands child
Old 04-10-2013, 03:43 PM
techinspector1's Avatar
Wiki Edits: 326
With all due respect, a fellow can make a high-performance pump from a stock pump with a flat piece of thin material tacked or pop riveted to the impeller......
Flow Kooler Water Pump Disc - Water Pump Tech - Car Craft
Also, before installing the pump, grab the fan drive end of the shaft with one hand and the impeller with your other hand and give the whole mess a twist. I have found overheating problems from the impeller spinning on the driveshaft and not moving any water. (This is one tough sum***** overheating problem to find).
Old 04-11-2013, 02:49 PM
That is sick
SBC Long water pump or short water pump? johnnnz Engine 28 08-21-2011 01:20 PM
short water pump vs long water pump Studedean Engine 9 07-20-2011 03:38 PM
SBC short water pump vs long water pump and other questions Jag Daddy Engine 9 04-02-2004 09:29 AM
power steering from long water pump to short water pump kellyem Suspension - Brakes - Steering 7 02-22-2004 07:22 PM
Milodon High Volume Water Pumps Jag Daddy Engine 2 04-11-2003 06:15 AM
