I am not familiar with the Mini Cooper headlamps, but if they are HID lamps there will be a solenoid in the headlamp that drops a shield in front of the lamp source for normal running and then removes the shield for high beam. That could be what the other connections are for.
Vince |
Mini cooper headlights
thanks, on the back housing it has 2 set screws that goes to the inside and on this sealed unit with the 4 wires on the inside it also has something similar to the connections of the set screws. i saw when you switch the lights on on a mini the lights goes up and then down, i think it is maybe something like that or you can set the height electronically from the inside of the vehicle, but i still need the wiring diagram to be able to connect those wires if i want to use it.
I can connect the lights without that but i might just need to set the light a little more than with just the set screws. Last edited by chevyfs; 05-07-2008 at 08:21 AM. |
| Installing a mini starter on my Chevy | vern kelly | Electrical | 5 | 09-09-2009 02:41 PM |
| Mini Cooper Headlight Connectors | tc33 | Electrical | 8 | 05-17-2009 09:05 AM |
| Mini Cooper S Headlight Wiring | tc33 | Electrical | 5 | 11-24-2006 12:17 PM |
| HELP FIND PROJECT MINI COOPER | PropanePower | General Rodding Tech | 10 | 06-13-2003 09:16 PM |
