Mini Spool for street use - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2005, 06:13 PM
Last journal entry: Future Plans
IM just wondering if anybody here runs a mini spool on the street and what there thoughts are about them. Im having some trouble finding a descent posi for my 9" and everybody i have talked to says to try a mini spool first
Old 02-28-2005, 06:29 PM
Wiki Edits: 49
Only an idiot would run a mini spool on the street. They are designed for racing only and can be very dangerous when used anywhere else. Especially on any kind of wet or slippery pavement.
Spools run on the street eat up tires and put abnormal stress on axles and differential components. Do yourself a favor and invest in a good posi unit or if you feel the need for something better go to a Detroit locker but never and I mean NEVER run a mini spool on the street.
Centerline
Old 02-28-2005, 07:32 PM
Lonestar's Avatar
"May the Schwartz be with you"
Last journal entry: Finally getting going...
We ran a '62 Impala years ago with a locked differential. The thing felt like it was going to tip over on a highway curve,
Remember that you are guiding a 2 ton missile and have the obligation to do so with the safety of others foremost in your thoughts.
Do not run a locked differential on the street.
Old 02-28-2005, 08:09 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
it sounds like you are looking for a cheap posi.
The 9 inch Ford is the small block chevy of rear ends. Parts are every where for the Ford 9 inch.
I would advise not using a spool or mini spool on the street
What's a spool and mini spool? 84Z Transmission - Rearend 2 01-31-2005 07:33 PM
mini spool camino_man Transmission - Rearend 3 02-08-2004 06:34 PM
mini spool in 9" ford kid Transmission - Rearend 0 09-18-2003 09:41 PM
mini spool on the street? kid Transmission - Rearend 5 05-24-2003 12:59 PM
Mini Spool Question Mustang_Killa66 Transmission - Rearend 6 02-24-2003 06:24 PM
