mini starter - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-21-2008, 09:12 AM
mini starter
I have 350 with the mini stater trying shim starter,with shims right now I have appox. 1/64 in between starter gear and flex plate {168 tooth).If I
add another shim it does not seem to get better.Is teeth to close?
PS. this is a pain in the ?
Thanks
Old 09-21-2008, 10:25 AM
boatbob2
starter shims.......
Hi,i have only had to shim 1 starter,i used a straightened out paper clip,then put it between flex plate teeth and starter teeth,then shimmed til it was a good fit. that was on a standard chev starter,i have never used a mini-starter. but,i think it would be the same way to check it.
Old 09-21-2008, 02:58 PM
dawg's Avatar
NAVY VETERAN
I hope you didnt get a proform mini starter!
Proform Part #67052
I had so many issues with that starter (loosening and grinding)
finally pulled it to find the mounting block was cracked (cheap casting)
I went and bought a summit protorque starter and never needed shims and never had any issues.
Old 09-21-2008, 05:40 PM
There have been many problems discussed about the "mini" starters and most of them have boiled down to very poor quality control of the casting and machining of the mounting frame. If your starter gear is too close to the flex plate, the starter will not engage. Shimming will move it away from the plate and engagement will occur. If it is too far away, skipping will occur and there is no fix for this except milling off some material from the mounting frame surface, which is not practical unless you have a milling machine and the ability to use it with skill and precision. The best thing to do is return this starter and keep trying until you find one that is manufactured correctly or give up and order a quality one such as Power Master.
Trees
Old 09-21-2008, 05:56 PM
Its a tilton mini starter,I have never had to shim before so I am kinda lost in how to.Every thing looks good on starter .Doing the paper clip thing almost have it, just don't know where to put shims..
Installing a mini starter on my Chevy vern kelly Electrical 5 09-09-2009 02:41 PM
Wiring a mini starter in a points system on 350 Chev. modelateacher Electrical 5 03-06-2008 11:52 AM
mini starter problems gilbert773 Engine 1 10-30-2007 01:37 PM
Mini Starter won't disengage.. SOLVED.. Theresa Shank Engine 2 11-20-2006 08:30 AM
Help With Mini Starter (Docvette) Canadian Charlie Electrical 6 06-05-2006 03:00 PM
