Mini Starter Brace? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2010, 06:28 PM
Mini Starter Brace?
I've read about the importance of a starter brace for a sbc, and seen them advertised, but never saw one installed. I haven't seen one for a mini starter. Wouldn't a mini need the same bracing?
I was thinking of fabing up something for mine. I don't know if I can get a bolt thru the rear cover to act as a stud sticking out the back with a jam nut to hold it, or if I'll have to get something welded on, or even if its a good idea to try. Will I just damage the starter since it dosen't seem to have any provisions for a brace in its design?
If I did get a stud on it, where would be a good place to attach the other end of the brace? I thought about the 2 bolt holes near the deck, but I may have to use them for a dipstick? I don't know. I haven't been able to find a dipstick for a vortec block so I don't know what one looks like? I just realized that maybe I could make a combination starter brace/dipstick bracket.(1/8" steel?)
If anyone could post a link to an advertisement, or pictures, or comments on design or feasibility I would be grateful! By the way, why would a factory block have the hole for the dipstick plugged? Sorry for so many Qs.
Thanks,
ssmonty
Name:	DSC02692 (Small).JPG
ID:	45612   Click image for larger version
Name:	DSC02694 (Small).JPG
Old 05-11-2010, 06:41 PM
poncho62's Avatar
Wiki Edits: 5
On the older Chevy starters, one of those bolts holding the motor on the starter housing used to have a stud on the end to attach the brace.......The other end of the brace went to a 5/16 threaded hole in the block.
Question on SBC mini starter bolt pattern eric32 Engine 2 11-10-2009 08:43 PM
Installing a mini starter on my Chevy vern kelly Electrical 5 09-09-2009 03:41 PM
Starter shifting and grinding.. new starter? Where does starter brace go? 84Z Engine 8 11-12-2007 03:44 PM
small blcok chevy! The ultimate starter problem! S.O.S. sugar ray Engine 11 07-19-2007 09:07 PM
Mini Starter won't disengage.. SOLVED.. Theresa Shank Engine 2 11-20-2006 09:30 AM
