mini starter problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2007, 09:16 PM
im working on 1962 chevy nova just drope in a 383 stroker with a 350 turbo trans but haveing problems with the starter i bolted the starter to the engine with no shims because with shims the starter was not grabing on the flex plate ok. i started a couple of times with no problems but once i let the engine run for like tens minutes and turn of the engine to tray to start the engine back on i here the starter grinding againts the flex plate could be that the engine gets harder to start when its hot or bad mini starter
Old 10-30-2007, 01:37 PM
dawg's Avatar
NAVY VETERAN
maygbe the starter is loose?
youll have to use loctite on the threads
Chevy starter problems downonthebayou67 Engine 10 03-29-2010 12:55 PM
SBC starter problems punk1c5040 Engine 26 12-28-2008 07:58 AM
mini starter help SSon18s Electrical 1 02-12-2007 03:07 PM
mini starter problem novaman30274 Engine 7 02-06-2007 05:33 AM
Help I have starter problems!!! CrazyT Engine 4 03-22-2003 06:06 PM
