Mini starter works only intermittently? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-03-2010, 04:29 PM
I have a Powermaster ultra torque starter part number 9426 which works only on occasion. I can start the car lets say ten times and it will start up no problem or grinding or buzzing, then i may try to start it later and it makes a buzzing noise, but i don't think its grinding the teeth on the flywheel. If it needed shimmed would it not make a grinding type noise all the time? The warranty is up on this starter, also i used it in a prior application with no problems. I just installed it in my current project. This starter was almost 300 dollars when i bought it, does anyone know what the problem may be?
Old 08-03-2010, 04:36 PM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
Probably needs a solenoid. Many starter and alternator shops could repair it for you, or get you the part.
Old 08-03-2010, 05:42 PM
sbchevfreak's Avatar
Licenced Automotive Technician
make sure it is properly grounded. Poor grounds can cause this type of malfunction.
Old 08-03-2010, 06:53 PM
Thanks for the responses, ill check the ground and if that doesn't work i see if its the solenoid, hopefully its one of the the two.
mini starter shearing teath off my flex plate chevy1500z71 Engine 5 03-22-2009 10:15 AM
Which Mini Starter to buy? mkjarobinson Engine 34 03-06-2009 11:04 AM
Wiring a mini starter in a points system on 350 Chev. modelateacher Electrical 5 03-06-2008 12:52 PM
Mini Starter won't disengage.. SOLVED.. Theresa Shank Engine 2 11-20-2006 09:30 AM
Carry on from other Starter POST dollybud Electrical 0 09-26-2003 06:48 PM
