mini torch on bumpers to stop them from being fur burgers? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2011, 08:24 PM
put up or shut up
I was told not to put 80 grit on bumpers anymore cause the primer is thin but I've heard if after you put 80 on it you use a mini torch and quickly go over the fur burger and it burns off off the plastic bumper. Can anyone vouch for that?
Old 06-10-2011, 09:39 PM
I guess it depends on the extent of the damage. 90% of the time you are going to have to put primer on the repair area anyway.
Old 06-11-2011, 01:36 AM
put up or shut up
I mean not burn off the bumper but burn off the fur left from 80 grit, which helps instead of having to go over it with 180 and 320 forever.
Forney arc torch. CrashFarmer2 Garage - Tools 5 03-10-2010 10:46 PM
Which to get first Torch or Mig? SteveU Garage - Tools 32 09-19-2008 10:13 PM
saw it or torch it??? REALGONEKATT Suspension - Brakes - Steering 3 07-03-2007 03:30 PM
Does The "Stop Leak" Stuff Stop the Rear Main From Leaking? daveh Engine 7 08-02-2005 09:43 PM
torch or saw wickedways Transmission - Rearend 10 09-13-2003 12:09 PM
