mini tub nova questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-22-2007, 01:36 AM
Sagacious's Avatar
Do you feel like we do?
i have a 73 nova hatchback that i bought a minitub kit for, will be installed soon. my question is will i be able to use a 'regular aftermarket' rear swaybar? if so who makes the biggest and best one i can get? i am looking to reduce bodyroll as much as possible i already have the 1 1/8'' swaybar up front. i need new HD coils up front but should i buy an air-ride kit for up front or is it not really needed?
i hear one of the best things i can do for up front is use the TALL 2'' drop spindles that have the balljoints raised 1.5'' for better camber. if i do this i dont really need air suspension right? i am running 17's /w low pros all the way around. thanks.
Old 11-25-2007, 06:21 PM
All I can say is measure 4 or 5 times and only cut once ...
Deuce ... Moderator
1968 Nova SS is about to end its Life Seagroves Hotrodders' Lounge 50 10-20-2009 06:04 PM
Installing a mini starter on my Chevy vern kelly Electrical 5 09-09-2009 02:41 PM
mini spray gun porter cable quack Body - Exterior 5 04-19-2006 08:47 AM
A Body mini tub question wally8 Suspension - Brakes - Steering 1 08-11-2004 05:09 AM
Questions, questions, questions? slider in wa Transmission - Rearend 2 09-27-2003 02:01 PM
