mini tubbing a 73 nova - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-11-2007, 04:54 PM
Sagacious's Avatar
Do you feel like we do?
ive got a 73 nova and i want to mini tub it. would i be able to use the stock spring location and fit a 10'' wide rim under there? im not looking to change the axle either. but ill do what i have to. i was wanting to fit 18x10 low pro tires. id appreciate the help, thanks.
Old 10-12-2007, 07:20 AM
Never owned a 73 Nova ... but there are companies which make a kit to move the springs inward. I have installed a few of those kits under the 68 to 72 Novas. Works good and gives plenty of room for 10 inch wide tires.
Old 10-12-2007, 10:12 AM
novajohnb's Avatar
It'll go, or it'll blow...
I have a '73 nova with 10.5" x 30" tires and NO mintubs.
there is no inner wheel well (where a mini-tub would go) rework, beyond bending a lip inward and hammering bulges in the sheet metal.
You'll run out of room with the stock shock location and then the stock leaf spring location before you need mini tubs.
Do you know the actual size of the 18x10 tires? (diameter and section width corresponding to the rim width you plan on using) A 30" diameter tire can fit with enough clearance for street use with some hammer work, anything shorter and you gain clearance in the front and back of the wheel well and the outer wheel well lip.
You can gain clearance on the outer wheel tub by rolling the sheet metal lip in. The old school trick was use an old baseball bat. I rolled the metal by starting with trimming the outer sheet metal lip and bending upward with vice grips all the way around wheel well. Then using progressively larger sized deep sockets and a 1/2" drive ratchet, I rolled the sockets between the tire and body.
Try searching this forum, as this topic has been discussed before. Try the thread below for a no cost neat tool you can make to measure tire clearance and wheel backspacing.
backspacing question
If you can get the rim you want with the right backspacing, it makes things allot easier. One more thing, check both driver and passenger sides. I can almost guarantee they will differ on spacing.
Old 10-12-2007, 10:17 AM
novajohnb's Avatar
Forgot to add, you mentioned stock leaf spring location. A 10" wide tire is close to the stock spring, but streetable with the right backspacing. The tires hit the shocks before the leaf springs. Like Deuce mentioned, moving the shocks inboard is needed on the really big tires.
Also, 73&74 nova rear frames and inner/outer wheel wells are the same as '68-72.
72 nova door panels to 73 doors... fireforsin Interior 2 02-18-2008 04:45 AM
Hello Ya'all, Proud owner of 73 Nova and a new car loan MCSEllis Introduce Yourself 9 08-31-2006 08:07 PM
Tubbing a '62 Nova snowman77 Body - Exterior 4 05-26-2004 08:58 AM
73 to 70 nova brake swap Gassman Suspension - Brakes - Steering 5 04-13-2004 02:28 AM
Big block for my 73 Nova Hatchback? 73 Nova Guy Hotrodders' Lounge 7 02-26-2003 10:40 AM
