Mini-Tubs - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2003, 03:40 PM
69 chevelle SS's Avatar
Mini-Tubs
I have a 1069 Chevelle SS 396 that I would like to run wider tires on. My question is if I leave the Wheel wells alone in the rear how large of a tire can I run.....and with mini tubs will i be able to keep my backseat.
Old 07-05-2003, 11:06 AM
Tanman's Avatar
mini tubs
I run mini tubs on '64 Chevy II to get the most wheel I can. I did inboard my spring perches (typical for Chevy II) and I was able to trim all the excess metal coming out from the frame. I still have my back seat which I had to modify slightly. The frame on the back seat was cut in a few places to fit around the tub but you wouldn't know to look at it. I am sure you could do the same with your back seat and save it. Good luck.
Cheers
Tanman
Old 07-07-2003, 09:39 AM
gt2betubbed's Avatar
Kid With A Wrench...
Last journal entry: The Blower and test fit.
There's a guy down the street that's running 325/50/r15 bfg drag radials on his 70 chevelle. They look huge, and he said all he had to do was roll the fender on the outside and a little pounding with a hammer on the inside. I didn't ask him the back spacing on his wheels though, but they were 15x10 ultralites. It looks like it's mini-tubbed.
