Mini valve spring pressure tester? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2007, 11:25 AM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
I did a search on ebay and found people are selling a kind of mini valve spring pressure tester that you can use in a vice or a drill press, has anyone ever used these and are they any good? Its only $60!!
Also I saw another kind that uses a beam type torqe wrench to compress the spring and has a table to covert the torque value to pressure or something like that.
Old 02-12-2007, 12:02 PM
Last journal entry: More on the Cobra Engine
Sure they work great for valve springs and are just as accurate as any other type measurement device. I bought mine from Summit Racing and while it works just fine for the valve springs, I also have a very special use for it. They work great at measuring the tongue weight on a trailer.
Old 02-12-2007, 02:06 PM
Yep, got mine from Summitt and it works great.
Thanks for the tip on the trailer tongue, had'nt thought of that.
Old 02-27-2007, 12:07 PM
MOPAR or NOCAR
Tongue weight?
You mention that you can use this device to measure tongue weight. What conversion do you use to calculate that? Thanks.
Fabricating intake manifold. gemini86 Engine 25 10-02-2009 01:10 PM
Rhoads Lifters yellow69firebird Engine 20 02-20-2007 06:24 PM
Too Much Spring Pressure? Dorf02 Engine 9 01-10-2006 12:30 AM
valvetrain gurus: need help identifying mysterious valve noise blndweasel Engine 10 03-04-2003 07:59 PM
AOD throttle valve pressure port mustang66maniac Transmission - Rearend 2 01-08-2003 02:44 PM
