minimal wiring needed for 83 chevy pickup - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-11-2010, 08:47 PM
new here. just picked an 83 chevy c10, according to the vin it originally had a 6.2ldiesel, but now has 305 w/3 speed auto. has lots of old connectors wadded and taped to firewall. after searching under the dash, i found they go to an ecm. also previous owner installed two toggles as start switch, one toggle powers distributor, other is a momentary to the starter. trying to figure out best way wire thing so i still have my lights, turn signals, heater, and wipers. by the way truck does not have power locks or windows. still need key to unlock steering wheel and acc power. i am wanting to get rid of as much useless wire as possible. any help will be appreciated.
Old 09-11-2010, 09:06 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Start here. Try to find out what year the motor/ECM are.
www.alldatadiy.com
Get the year for the motor/ECM.
Can't do it without a good shop manual.
Post back.
vicrod
Old 09-11-2010, 09:40 PM
maybe not an ecm. did some looking, could it be the esc controller?
Old 09-12-2010, 06:11 AM
Black box near the steering column wit a circuit board in it?
Shane
Old 09-12-2010, 11:54 AM
module mounted behind glove box
Old 09-12-2010, 01:57 PM
randolphi's Avatar
bEHIND GLOVE BOX
If you post any numbers on stickers, from the module, behind the glove box, and state color of connectors, how many connectors, and the number of spaces for wire, in each connector, we can tell a little more about the wires you dont need.
Old 09-12-2010, 03:39 PM
Correct. California trucks may have had the CCC system and ECM, but 49 state trucks did not. Some did use the ESC system, however.
Old 09-12-2010, 03:48 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
I recently disassembled an 81 with a 305
the ESC was a 'stand alone harness that should come right out.
But if your truck was a 'rattler' those could be for something else.
Chevy Oil Pickup Installation Question leejoy Engine 13 02-11-2008 02:17 PM
Chevy engine swap info needed ChevyJim Engine 2 12-31-2007 03:33 AM
58 Chevy Apache : Brake Lights / Wiring Harness Rathimis Electrical 3 12-13-2005 08:34 AM
wiring a chevy tank valve fryed Introduce Yourself 1 11-20-2004 03:30 AM
Wheels for a 1967-72 Chevy Pickup 68ChevyMan Introduce Yourself 1 07-26-2004 09:09 PM
