Minimum filter requirements for spraying primer? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-16-2005, 10:52 AM
I am wondering what are the minimum filter requirements needed for spraying primer. I literally have a compressor with a 25 ft hose and that's it, what type of filter(s) do I need to be able to spray Featherfill? Part numbers or links would be great.
Thanks in advance!
Old 12-16-2005, 10:09 PM
You can get by with a cheap wall mounted water trap $60, attach a desicant snake hose $15 before your 25 foot hose and for added insurance a cheap disposable desicant mini filter $8 just before the gun. You're best off plumbing some hard line between the compressor and water trap with a few downlegs. Air humidity factors in and also how hot your compressor gets.
Old 12-16-2005, 10:30 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Just be SURE to CLEAN your gun as soon as your done spraying that G2 as it WILL harden quickly. It's like working f'glass and uses the same hardner,so don't expect an hour potlife in that gun.
Old 12-17-2005, 10:56 AM
Thank you for the replies.
Regarding the pot life...I assume that since I will be coating the entire car I will have to empty and refill the cup a few times. I guess I will have to completely clean the cup & gun before each fill up?
Thanks
Old 12-17-2005, 03:07 PM
37ford4dr's Avatar
bobs77vet
Last journal entry: frame repair
don't skimp on using a filter at this point......the primer is the base for the paint, you don't need oil impregnated in the primer
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 04:07 AM
WARNING Mr Gasket Fuel Filter Problems SilverFox2 Engine 11 09-08-2008 05:36 PM
FRAM air breathers!!!! Robbie Engine 70 09-22-2005 06:52 PM
Filter requirements while painting Dad&Son Introduce Yourself 1 09-14-2004 08:35 PM
good primer over ok primer hoss Body - Exterior 1 09-17-2003 02:28 AM
