Minimun battery size/capacity, race car - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2012, 11:53 PM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
no accesories electrical system, race car only, what would the minimum size battery I should use just to crank the engine, it's a supercharged SBC with only 7.8:1 CR so no need for a big starter motor.
I'm thinking a small 55 a/h like 350 CCA batt from a corolla will be enough
it jump starts stock SBC just fine, no need to crank for more than a few seconds. maybe even a smaller batt?
I'm in a quest to save weight as much as possible
Old 05-01-2012, 04:27 AM
poncho62's Avatar
Wiki Edits: 5
Are you using a charging system....electric water pump etc?
A larger battery in the rear may be of an advantage......
Old 05-01-2012, 04:53 AM
EOD Guy's Avatar
A Miata battery is about half the size of even the smallest battery that fits in a normal car..... full 12v etc... I have one in my dune buggy.
Old 05-01-2012, 10:57 AM
Augusto's Avatar
35 amp alternator, MSD box and large coil, no other electrical accesories, I was also thinking of installing a larger pulley in the alternator.
the batt goes in the rear, just behind the cab.
Old 05-01-2012, 11:01 AM
Augusto's Avatar
what size is that battery? amp/hour rating?
Old 05-01-2012, 11:19 AM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
Race Engines with high compression need Amps-I would recommend this:
http://www.summitracing.com/parts/XSP-D1600/
Old 05-01-2012, 11:55 AM
Augusto's Avatar
my friend you didn't read my first post:
supercharged race engines have low compression, no need for big amps or starter motors.
Old 05-01-2012, 04:42 PM
EOD Guy's Avatar
I'll ck on it and post
Old 05-01-2012, 04:46 PM
EOD Guy's Avatar
labels were gone... but this is the one I bought ..... looks like 370 CCA
http://www.interstatebatteries.com/c...430-2147384906
Old 05-01-2012, 10:33 PM
Augusto's Avatar
I think your link gave me a true clue of why such big batteries are often used by the OEM:
" this 370 CCA automotive battery will meet or exceed your vehicle`s starting requirements in any hot to moderate climate"
I guess a small, light weight battery will not crank over in cold weather, so they use big ones jut to be sure. We have here temperatures in the 70's and up all year long so there'll be no climate issues.
this battery weights 20.5 lbs, the ones I use with V8's weight 32+ lbs.
there is a big difference here.
btw, I checked and the miata is a 45 amp/hour bat, the chevy's is 65 amp/h
I made this experiment this afternoon, and a little 36 amp/h battery from a Geo Metro cranked up very well a stock chevy 350 engine that has more compression than mine.
thanks a lot amigo.
Drawing: Great Race "Essex Race car" lincoln highway jony Hot Rod Art 3 11-30-2011 02:27 PM
Battery Cable Size: AmericanPackMule Electrical 5 07-08-2008 12:17 PM
battery size yragat Electrical 15 05-20-2008 07:49 AM
battery size ? jimmy1 Electrical 8 03-16-2008 10:45 AM
Battery cable size 49dream Electrical 15 02-08-2005 01:41 AM
