miniscual tiny white dots in clear coat - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-20-2011, 02:38 PM
Can anyone tell me what i am doing wrong, this problem only happened about 1 hour after putting on the clear coat thanks
ID:	57681   Click image for larger version
ID:	57682   Click image for larger version
ID:	57683   Click image for larger version
Old 08-20-2011, 04:18 PM
Last journal entry: Hood
What are you using for materials?
Old 08-20-2011, 05:01 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Looks like solvent pop..caused by applying too much material too quickly not allowing trapped solvents to come out..
Sam
Old 08-20-2011, 05:17 PM
materials i used are SEM 39863 adhesion promoter, SEM 39133flex primer surfacer, OMNI MBC#1 base coat,1-1 USC 20 glamour clear coat 2.1 voc with slow activator 4-1. thanks
Old 08-20-2011, 08:50 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
___________
Old 08-21-2011, 07:07 AM
deadbodyman's Avatar
Wiki Edits: 11
Did you use a tack rag before you cleared it,strained the materials,is the gun clean????
Old 08-21-2011, 11:33 PM
Rag top bird's Avatar
Hot rods are still the king
is this the way it came out after spraying or have you resanded it
Old 08-22-2011, 09:07 AM
Old Fool's Avatar
Can you clarify which white dots you are referring to?
If it is the million of them , it appears to me that you have sanded clear that was sprayed very dry and the white spots are low spots between all the dry bumps that were sanded down.
the large white spots? possibly iso clumping from moist air or ? Have to ask BarryK about that .
Click on photo to enlarge
Help with PPG Deltron base coat paint and clear coat Please smithkustoms Body - Exterior 31 01-12-2012 08:43 AM
Clear Coat White Dots Mooe Body - Exterior 9 06-23-2011 12:15 PM
Base coat/clear coat urethane over acrylic enamel mervhudson Body - Exterior 5 04-23-2011 11:56 AM
Couple of base coat/clear coat questions bigbrowndog Body - Exterior 17 11-05-2010 09:37 AM
tiny bubbles in clear coat bruce-77346 Body - Exterior 19 04-30-2006 10:00 AM
