If it is the typical sag for headliners there is nothing you can do for it short of pulling it out and re-upholstering it. What is happening is the foam is degrading and is separating from the material allowing the material to drop down, it's a very common problem. It will only get worse over time.
Yep, to fix that you will have to drop the headliner and recover it. If you try to make simple repairs, you will find more as time passes. The thing that causes most headliners to fail is cigarette smoke and perfume, they tend to degrade the foam causing the fabric to fall.
Everybody is right, once it starts to come down it will only get worse. If you take down the headliner board, you can clean off the old fabric and foam combination and replace it with new stuff. It's not that expensive, and you don't need that much for a pickup.
It is not that difficult, usually the headliner board comes down in one piece. Clean all the old junk off, get a piece of fabric the size to fit. Use a good grade contact cement (this is the most important step). Do not use 3M #77 or most anything you can get from a home improvement store in a rattle can. Most if not all will fail in the heat of summer and the headliner will sag again. If you can go by an upholstery shop see if you can buy a quart of DAP Landau Top adhesive from them( bring an empty can). Spray both the headliner board and the back side of the headliner material. Allow time to dry then starting from the middle apply the fabric and work outward.
used car dealers around me drop the headliner down, seperate it and use spray adhesive in between and use a large airbag to hold it up while it dries... this is the only way I know of 'fixing' what's there, short of completly redoing it, but I question how long it will hold
That would be O.K. if the headliner material separated cleanly from the headliner board. In actuality, that would be extremely unlikely so they would just be prolonging the inevitable.
When I get home, I'll have to take a look at it and see what will be entailed. Knowing me, I will do it myself then that will lead into many other things!
You can do what my son did to his 1984 celebrity. He took an air powered roofing stapler and stapled the headliner back up to the roof. He said it fell down so he had trouble seeing the road. Also don't forget to bend over the staples and put silicone on them to prevent water leaks. Worked good, the guy he sold it to didn't seem to mind.
It was just sagging in front of the windshield, the rest of it looked great.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
