Minor Headliner Sag - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-05-2010, 08:50 AM
Minor Headliner Sag
I've read through quite a few headliner threads on here but they all seem to refer to major sags in current headliners.
I have 97 Dodge Ram with two sags, one in front of each fold down shade.
Is it necessary to remove the entire headliner to repair just those two parts? Or can it be done with it still in the car?
Old 01-05-2010, 09:04 AM
302 Z28's Avatar
If it is the typical sag for headliners there is nothing you can do for it short of pulling it out and re-upholstering it. What is happening is the foam is degrading and is separating from the material allowing the material to drop down, it's a very common problem. It will only get worse over time.
Vince
Old 01-05-2010, 10:15 AM
54merc's Avatar
Stallions Auto Interiors
Yep, to fix that you will have to drop the headliner and recover it. If you try to make simple repairs, you will find more as time passes. The thing that causes most headliners to fail is cigarette smoke and perfume, they tend to degrade the foam causing the fabric to fall.
Old 01-05-2010, 10:43 AM
Grrr...that's not what I was hoping for, but expecting.
Thanks for the responses.
Old 01-05-2010, 01:51 PM
DanTwoLakes's Avatar
Wiki Edits: 22
Everybody is right, once it starts to come down it will only get worse. If you take down the headliner board, you can clean off the old fabric and foam combination and replace it with new stuff. It's not that expensive, and you don't need that much for a pickup.
Old 01-05-2010, 02:12 PM
Is this something that I could tackle myself, or would I be better of taking it to a shop?
My problem is there aren't many reputable shops around that do this where I live (that I know of).
Old 01-05-2010, 02:39 PM
302 Z28's Avatar
It is not that difficult, usually the headliner board comes down in one piece. Clean all the old junk off, get a piece of fabric the size to fit. Use a good grade contact cement (this is the most important step). Do not use 3M #77 or most anything you can get from a home improvement store in a rattle can. Most if not all will fail in the heat of summer and the headliner will sag again. If you can go by an upholstery shop see if you can buy a quart of DAP Landau Top adhesive from them( bring an empty can). Spray both the headliner board and the back side of the headliner material. Allow time to dry then starting from the middle apply the fabric and work outward.
Vince
Old 01-05-2010, 04:08 PM
Wiki Edits: 22
This job is more labor intensive than it is difficult. Check out this thread: CLICK HERE
Old 01-05-2010, 04:36 PM
Wiki Edits: 31
used car dealers around me drop the headliner down, seperate it and use spray adhesive in between and use a large airbag to hold it up while it dries... this is the only way I know of 'fixing' what's there, short of completly redoing it, but I question how long it will hold
Old 01-05-2010, 05:33 PM
Wiki Edits: 22
That would be O.K. if the headliner material separated cleanly from the headliner board. In actuality, that would be extremely unlikely so they would just be prolonging the inevitable.
Old 01-05-2010, 05:52 PM
Thank you for the tips/advice.
When I get home, I'll have to take a look at it and see what will be entailed. Knowing me, I will do it myself then that will lead into many other things!
Old 01-08-2010, 07:13 PM
You can do what my son did to his 1984 celebrity. He took an air powered roofing stapler and stapled the headliner back up to the roof. He said it fell down so he had trouble seeing the road. Also don't forget to bend over the staples and put silicone on them to prevent water leaks. Worked good, the guy he sold it to didn't seem to mind.
Old 01-08-2010, 08:07 PM
54merc's Avatar
How did he hide the staples?LOL
Old 01-08-2010, 10:23 PM
They just rusted like the rest of the car.
Old 01-09-2010, 08:18 AM
302 Z28's Avatar
Heck, just rip it all down and leave it like that.
Vince
1938 Terraplane leaf Spring Sag Cole Suspension - Brakes - Steering 5 01-19-2009 01:16 PM
sag on '73 chevy PU DENCOUCH Body - Exterior 4 08-17-2008 08:33 AM
Sag problem with R-M Diamont base Dirk Squarejaw Body - Exterior 1 07-01-2008 06:24 PM
How to fix sag in clearcoat? pszikszai Body - Exterior 7 06-28-2006 07:51 AM
Door Sag Nick Davis Body - Exterior 4 04-24-2003 04:04 PM
