minor ? - wet sanding vs color sanding - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-04-2008, 04:26 PM
Last journal entry: Several Car Projects
New clear coat repair system from 3M
Originally Posted by t66turbocobra
Here is the link to 3m for the interface pad. http://solutions.3m.com/wps/portal/3...beQTM5DLXZ75gl
I have seen that 3M launched a new clear coat sanding system. Sand damp with a Trizact abrasive in place of the dry Finishing Film is used. Then you follow it up with the Trizact Foam disc (3,000 grit) damp. Then buff with a new Perfect-it Rubbing Compound, Then Swirl Mark Remover, and Finally Ultrafina (optional) or a Hand Glaze.
New 3M Clear Coat Repair System
Last edited by edselman59; 07-04-2008 at 04:30 PM. Reason: added link to 3M website
  #17 (permalink)
Old 07-04-2008, 10:30 PM
302 Z28's Avatar
[QUOTE=edselman59] Then Swirl Mark Remover, and Finally Ultrafina (optional) or a Hand Glaze.[QUOTE]
Swirl mark remover looks fantastic till you wash the car then you see all the swirl marks that the swirl mark remover filled. Best bet is to skip the swirl mark remover and just use a foam pad with ultrafine compound, and also skip the glaze. And if it's fresh paint, give it a month or so then several coats of a quality wax.
Vince
  #18 (permalink)
Old 07-05-2008, 09:21 AM
I have to tell you Dewey, for a "virgin" like yourself, I would hand wet sand the clear it is WAY safer. The ORBITAL sander (Not a "DA") is the way to go to get it done fast, but good old hand sanding is pretty hard to beat.
Now, the brand of paper can make a BIG difference. I use Meguiars paper "Unigrit" (it is made by someone else, the name escapes me now) and is the BEST, hands down, NO comparison. It makes 3M look stupid, lasts MUCH longer and cuts more even, MUCH better than every brand I have ever used and I have used just about everyone you can find out there. It is EXPENSIVE, about twice what 3M costs, but it is well worth it.
Click here for Meguiars
Get yourself a little 3m "squeegee" #05518. This will allow you quickly squeegee off a small area and see where you are at in the sanding process throughout the sanding process so you DON'T sand thru. You are in complete control.
Sand a little, squeegee off the water and see what you have, then sand a little more. It is real user friendly.
I have to say, color sanding and buffing is one of my most favorite steps, because of this total control you have. You can make a finish near flawless, you are in complete control of the finished product.
Have fun!
  #19 (permalink)
Old 07-05-2008, 10:47 AM
Swirl marks can be tricky
[QUOTE=302 Z28][QUOTE=edselman59] Then Swirl Mark Remover, and Finally Ultrafina (optional) or a Hand Glaze.
Vince
I would say that if you are getting swirl marks after Swirl Mark Remover then you are getting some filling. Solution: Go a little longer with the Swirl Mark Remover, then Step to the Ultrafina OR get your hands on a 5" Dynabuffer (5" random orbital buffer) and use it with either Swirl Mark Remover or Ultrafina. That is typically what you see in production floors for large area repairs (busses, cars, dark colors on boats, planes). The "throw" on the tool REALLY breaks up the swirl from the straight rotary tool. Like instantly! But be ready to pay a little for an industrial tool like this.
On most manufacturing process that I have run across, the 5" Dynabuffer cuts out at least 1 buffing operation in a sequence, and in a production setting that is huge.
  #20 (permalink)
Old 03-03-2012, 05:27 AM
Have fun!
Could it be Nikkens (Japanese) who makes the Unigrit?
I wonder if it's the same product Eagle Abrasives is selling?
  #21 (permalink)
Old 03-03-2012, 07:55 AM
shine's Avatar
Last journal entry: some progress
cboy , the most important thing for you is blue painters tape. it will save your butt . dont sand anything you cant buff and tape off all your edges and peaks until your last buff.
and i wet sand everything. when i'm done it is clean and rinsed ready for the next step. plus i hate the dust mess it creates when dry sanding.
  #22 (permalink)
Old 03-03-2012, 08:49 AM
deadbodyman's Avatar
Wiki Edits: 11
Heres another tip for ya Dew...after your done painting ,leave the paper on untill your done buffing makes cleanup a breeze,and if you have any louvers ,paper them off too..Its not just the compound being slung around ,its the wet sanding residue (clear) that is hard to get off after the water evaporates and it always seeks out the most noticable spots that are the hardest to get at...As your trying different wet sanding pads try a scuff pad folded in half with the half sheet of paper wraped around it,one of my favorite sanding pads for wet sanding
  #23 (permalink)
Old 03-03-2012, 09:01 AM
Originally Posted by deadbodyman
Heres another tip for ya Dew...after your done painting ,leave the paper on untill your done buffing makes cleanup a breeze,and if you have any louvers ,paper them off too..Its not just the compound being slung around ,its the wet sanding residue (clear) that is hard to get at and it always seeks out the most noticable spots that are the hardest to get at...
Here, Here, that clear sanding residue when dry is on of the hardest stuff you will every try to get off your.
I forgot about leaving the car masked up, I use to do that myself. I haven't seen it in years because the shop I work at doesn't do it, and I forgot all about that. It does save you some clean up that's for sure.
  #24 (permalink)
Old 03-03-2012, 09:18 AM
You can wet sand with the Orbital sander, our detail guys do at the shop sometimes (I don't know why they would "sometimes" but they do). But I just can't wrap my head around using a sander for this final oh so important step on a special car.
First off, I LOVE wet sanding and buffing a car, to me it's the final step of hands on connection with the down to earth passionate work you have done from the rusty metal. It's an emotional thing to me, to "rub" that finish that you have worked so hard to obtain, you have put so many hours of your life into it, I want to "rub" it to perfection with a piece of sand paper in my hand and work one on one with that finish until it is done. First off you have so much more control, sure you CAN get damn good with the orbital sander when it comes to detail, but the learning curve is damn steep. Plus, like I say, you loose that relationship with the finish that you have spent so much of your life making.
I honestly don't believe you can get the perfection we are after on a show quality job without hand sanding it. Though I have never tried, as I don't do this every day. I just stick with hand sanding if for nothing else, that "personal" connection with the finish.
  #25 (permalink)
Old 03-03-2012, 09:24 AM
shine's Avatar
i tear the car down. i want the tape off as soon as possible. if you are wet sanding there should be no problem with residue anywhere. i use the orbital up to 1500 then hand sand 2000-2500 then go back to the orbital for the 3000 .
  #26 (permalink)
Old 03-03-2012, 09:32 AM
I'm sorry, I am missing your point "if you are wet sanding there should be no problem with residue anywhere." Isn't that exactly when you DO have residue, when you are wet sanding? Now, if you have JUST a body doing a complete restoration where the body is painted and then you assemble it, I can see that you could use a lot of water and rinse it off and that sort of thing where you have no residue, is that what you mean? Me personally, I always have some residue to clean up in the jambs and, inner fenders, if the body parts are assembled on the car.
But this is all personal preference for each of us as we all do it a little different. Certainly no right or wrong in masking or unmasking or wet sanding or orbital sanding, just personal preference that's all. If we toss out these ideas of our personal preferences someone doing it for the first time or once in a while can pick up some different ideas on how THEY may want to do it.
  #27 (permalink)
Old 03-03-2012, 09:36 AM
shine's Avatar
i stopped bucket sanding over 20 years ago. i have a 1/4 inch hose with a bug sprayer end on it in my booth. there is no residue or sanding mud to deal with. yes with a bucket you will make a god awful mess of it and need to do a lot of clean up. that is why i stopped using the bucket, that and the scratches you can get from stuff in the bucket.
  #28 (permalink)
Old 03-03-2012, 09:56 AM
Ahhhh, ok I'm with you. I have never wet sanded that way. I can say that I NEVER get any scratches from something in the bucket because I keep it as lean as I would a drinking glass, literally. I keep the surface of the finish as clean as a drinking glass and I keep the sand paper and squeegee, yep, as clean as a drinking glass. But that takes a bunch of work so the sprayer seems like a great way to go. I may try that next time but like I say I don't do it all the time so between cut and buffs for me I'll probably just stick to the bucket.
  #29 (permalink)
Old 03-03-2012, 10:04 AM
shine's Avatar
i have a clear fuel filter on the hose. you would not believe what comes out of the water line. it's nice , i can use as little or as much water as i want . but i can keep it rinsed so it is ready for the next step. works great for a second round of clear. car is clean and ready. but then i do not do any collision work so there is little masking on my jobs.
  #30 (permalink)
Old 03-03-2012, 10:13 AM
LOL, Shine, a fuel filter on the hose, that is BRILLIANT! LOL, you sound as anal as me. What a great idea! Yeah, I may just give that a try. Of course I am a LONG way from that step on my next project. And like I say, honestly, blocking the primer and cutting the clear and polishing are my two favorite parts of the project, I'm anal like that. I love that fine tuning, it's what makes the difference between a nice car and a super nice car.
Interesting test on sanding base coat paint (against the data sheets recommendation) MARTINSR Body - Exterior 208 03-22-2007 10:52 PM
Sanding is the art pepi Body - Exterior 3 08-02-2006 10:40 PM
Sanding Help rcm800 Body - Exterior 2 04-06-2006 08:35 PM
Color sanding and Buffing questions. Z-Money Pit Body - Exterior 1 05-30-2005 09:41 PM
wet sanding and saving my finger tips.... onebadmerc Body - Exterior 14 12-30-2003 05:41 PM
