minor ? - wet sanding vs color sanding - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 03-03-2012, 01:30 PM
deadbodyman's Avatar
Wiki Edits: 11
actually that sounds even better than my pump bottle sprayer.....If it had a little valve to get the perfect flow ....hmmmmm
Hutchins has had an obital wet sander for years ,I believe that has a 1/4"or 1/8" line you just hook up to any garden hose , the water comes through the pad but I wouldnt advise using ANY kind off sander if the car wasn't painted in a booth and the operator hasnt done quite a few by hand first...If you have a lot of trash in your paint you cant hear it or feel it rolling around between the paint and the paper putting hellashish gouges in the paint,when you hand sand you feel it or hear it right away and can stop before the trash does any damage Just think of all the damage one grain of sand stuck in the paint can do when it breaks loose and gets rolled around by a sander...Ouch!
......PLEASE dont use an "electric" orbital sander for this kind of finish work..
.....Afros dont look so hot on white guys....
  #32 (permalink)
Old 03-03-2012, 02:45 PM
The hose idea is a great idea. Ever since the first time I read Shine post about the fuel filter I've been filtering my spray bottle water. I use the kitchen sink's drinking water filter (screws onto the faucet). Works great. I'm sure any calcium or other minerals from well water is definitely not helping after I just payed good money for uniform fine wet/dry paper.
I use a National Detroit 600 (inline-as in a fast back and forth pattern) and I love it. Great sander. It's heavy but it saves lots of time. I think it's faster than my Dynabrade Orbital. And I can use 1/3 sheets so paper cost is negligible compared to having to use discs.
I start with a dry 600 Mirka Abranet (looks like window screen). I start at 600 since I ALWAYS level sand everything before buffing. I don't sand all the way level but I get close with the 600 and it's easy to see because it's dry. This stuff lasts FOREVER. I love the product. Probably the most valuable abrasive I've ever tried and amazing on the ND 600 sander. Then I switch to 800 to level it and work through the grits to 2500. It's a pretty good system. I didn't like dry sanding. Too dusty and the paper loaded. I didn't like orbitals. A minor/shallow inline scratch that I somehow missed in buffing can pass off as normal wear or a customer's scuff. A pigtail from an orbital that I somehow missed can come back to bite me in the butt later. To me it's not worth it. I still use orbitals for before the color coat (400 and courser) but the only thing that touches clear coat is the N/D inline and the buffer. I should say that the trizact system worked ok. It and Mirka Abralon (foam backed abrasive disc) got the job done and pretty well. I didn't have to spend much time buffing. But again, one or two tiny pigtails that you could see in the right light angle was enough to say bye bye to the Dynabrade for me.
Speaking of... and while I'm on the topic, I did a test a while back using foam backed abrasives. Quite a big difference even in the amount of gloss just with the two different sanding patterns/tools. This was the last time I used only an orbital sander before buffing and I probably won't ever return. The pictures of the test are of around 1000 or 1200 grit foam backed (can't remember off hand). I found foam backed abrasives to sand finer than regular paper without a backing... i.e. 1200 is closer to 1500 or 2000.
ID:	63610   Click image for larger version
Name:	Orbital v Inline.JPG
  #33 (permalink)
Old 03-03-2012, 03:28 PM
I should add that since that test, I now find the foam to be useless in anything less than 3000. 3M did it right with the choice on what grit to add the foam backing for their trizact system (which I no longer use).
The reason I say it's useless courser than 3000 is because regular paper on a hard pad or rubber sanding block levels much better than something with give to it like a foam pad. Also, the regular wet/dry paper is cheap and the foams are very EXPENSIVE as in $3-$6 per disc.
I now use:
-Abranet P600 dry (lasts as long as probably 20 pieces of wet/dry)
-P800 - P2500 wet/dry in steps
-3000 or 4000 grit Foam pad (Abranet, or similar) and this is when I have it around.
-Buff
I also tested only using the Dynabrade at 4000 (sanding with the N.D. or by hand on all courser grits) and I still found a few pigtails after buffing when I looked hard and that was at 4000. That settled it for me.
  #34 (permalink)
Old 10-06-2012, 06:35 AM
Is anyone still using these old design inline sanders?
Interesting test on sanding base coat paint (against the data sheets recommendation) MARTINSR Body - Exterior 208 03-22-2007 10:52 PM
Sanding is the art pepi Body - Exterior 3 08-02-2006 10:40 PM
Sanding Help rcm800 Body - Exterior 2 04-06-2006 08:35 PM
Color sanding and Buffing questions. Z-Money Pit Body - Exterior 1 05-30-2005 09:41 PM
wet sanding and saving my finger tips.... onebadmerc Body - Exterior 14 12-30-2003 05:41 PM
