Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - minor ? - wet sanding vs color sanding
  #23 (permalink)
Old 03-03-2012, 09:01 AM
MARTINSR MARTINSR is online now
Originally Posted by deadbodyman
Heres another tip for ya Dew...after your done painting ,leave the paper on untill your done buffing makes cleanup a breeze,and if you have any louvers ,paper them off too..Its not just the compound being slung around ,its the wet sanding residue (clear) that is hard to get at and it always seeks out the most noticable spots that are the hardest to get at...
Here, Here, that clear sanding residue when dry is on of the hardest stuff you will every try to get off your.
I forgot about leaving the car masked up, I use to do that myself. I haven't seen it in years because the shop I work at doesn't do it, and I forgot all about that. It does save you some clean up that's for sure.
