Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - minor ? - wet sanding vs color sanding
  #31 (permalink)
Old 03-03-2012, 01:30 PM
deadbodyman's Avatar
deadbodyman deadbodyman is online now
Wiki Edits: 11
actually that sounds even better than my pump bottle sprayer.....If it had a little valve to get the perfect flow ....hmmmmm
Hutchins has had an obital wet sander for years ,I believe that has a 1/4"or 1/8" line you just hook up to any garden hose , the water comes through the pad but I wouldnt advise using ANY kind off sander if the car wasn't painted in a booth and the operator hasnt done quite a few by hand first...If you have a lot of trash in your paint you cant hear it or feel it rolling around between the paint and the paper putting hellashish gouges in the paint,when you hand sand you feel it or hear it right away and can stop before the trash does any damage Just think of all the damage one grain of sand stuck in the paint can do when it breaks loose and gets rolled around by a sander...Ouch!
......PLEASE dont use an "electric" orbital sander for this kind of finish work..
.....Afros dont look so hot on white guys....
