Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - minor ? - wet sanding vs color sanding
Old 11-21-2007, 02:27 PM
Centerline Centerline is offline
Wiki Edits: 49
Originally Posted by cboy
Just so I'm clear (so to speak). When painting BC/CC your reference to "color sand" would be sanding the clear coat NOT the base coat?
Correct. I try never to touch the base at all. Unless I have some sort of a problem, then I'll fix it and respray the panel with base before continuing.
