Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - minor ? - wet sanding vs color sanding
Old 11-22-2007, 09:03 PM
cboy's Avatar
cboy cboy is offline
Last journal entry: Finished
Originally Posted by t66turbocobra
I sand with a finishing D/A that has a interface pad on it.
What is an interface pad? I have a number of different pads for my D/A (rated by color for the different "grits" of compound or polish one would use) and also pads made of different materials (foam and wool) but I don't recall any being referred to as an interface pad.
Also, do you use, or would you recommend, this same procedure even in the event of fairly substantial orange peel in the clear coat? I would assume you take some sort of special care around any edges or sharp curves to prevent the D/A from burning through. Could you talk about that as well?
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
