mirror like reflection on metallic paint jobs - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-23-2012, 08:50 PM
somebody once said
Adam's Polishes Forums - View Single Post - No Mirror Shine
"Capturing a mirror like reflection picture in a heavily metallic paint job, especially silver is like trying to catch swordfish in the desert Bill... there usually isn't one!
The characteristics of metallic silver are going to be more of a 'glare' than a reflection. Just like you won't see 'deep' reflections in white paint, but you will in black"
Im trying to reproduce the reflection I get from black into a realistic metalic paint job(or at least try to get close) 2 stage bc/cc just dont look right to me, single stage metallic looks closer, not having a fine grained metalic down here in Nicaragua doesnt help either...
nice reflection on bc/cc black..
Old 08-23-2012, 10:36 PM
TucsonJay's Avatar
To be able to see clear sharp reflections, you need two things... a dark backgound color for contrast... and a veeeery slick finish! The sharpest images will come from a sanded and buffed finish.
Old 08-24-2012, 12:40 AM
put up or shut up
basically no mottling and as TusconJay says a good cutting and rubbing. We're talking no orange peel and buffed out well. None of this start polishing over haze crap. I'm talking a deep gloss and just a few swirls before you even switch over to a polish or swirl remover. THEN you will have a deep gloss and it will actually enrich the color. Not sure how to describe it other than to say it pops and has a lot more sheen than your average new car.
This can never be achieved with single stage and if it can it will most likely be short lived. Not very ideal to cut and rub a SS metallic either.
Old 08-24-2012, 05:52 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
You can clearcoat a single stage like a good urethane and get
any finish you want, the color will be richer too.
It will also be more durable than basecoat that's been clearcoated
because it's all urethane, color and clear.
Old 08-24-2012, 05:31 PM
thank you guys for your help, but I guess I didnt ask the correct question, what Im after is a realistic as possible metallic coat, and Bc/CC metallic just doent look right, its not natural, it looks to be too glossy but not natrualy reflective as hand polished metal, have you seen how weird chrome looks after being clear coat it? too glossy but the natural reflection of chrome is not there once you clear coat it, single stage metallic looks more natural but still is not as reflective as I wish it was,
I did this piece yesterday,
this is what I did, before applying the single stage metallic I did 2 coats of single stage glossy black, went heavy on the thinner on the metallic(2 coats) seems like the gloss from the black is some how leaking thru the matallic, I did this using nothing by enamel, next time Ill try an even glossier black and make a comparison between how one should spray single stage metallic and the process mentioned above
Old 08-27-2012, 10:53 PM
ok guys after afew more days, I went back to the same piece and buff it out and it has the natural shine I was looking for...
some pics...
videos
Realistic Metal 1b - YouTube
"> Realistic Metal 1b - YouTube
" type="application/x-shockwave-flash" width="425" height="350">
Realist Metallic 1c - YouTube
"> Realist Metallic 1c - YouTube
Old 08-28-2012, 01:57 AM
guys now after lots of research seems that what I was looking for and what I came with its basically the harley davidson 2003 anniversary edition silver paint(black basecoat and see thrue silver)... cool...
Old 08-28-2012, 08:50 AM
Arrowhead's Avatar
EFI Rules and Carbs Drool
Last wiki edit: The FREE T Bucket plans
Last journal entry: Sold Everything for a new project
Wiki Edits: 5
I think you've replicated what is marketed as "chrome paint". Basically the black is what is giving the vivid mirror reflection and the silver colored coat gives it the apprerence of chrome. I think the issue with silver is the size of the flakes. The larger the flakes, the more the reflection is dispersed. The silver on my hot rod has large flakes so the reflections are "foggy", but when looked at from an angle, the polished clear finish reflects the image clearly. But the larger flakes really pop in the sunlight and really sparkle.
Old 08-28-2012, 11:11 AM
I think you are on the spot, and so true on the size of the metal flakes, I think I could get better results with smaller sized flakes and even shiner black base...
Dummy Newb Q--Can I get metallic paint without the metallic? superkaz661 Body - Exterior 4 10-07-2008 05:16 PM
Lacquer paint jobs Polish Painter Body - Exterior 6 06-25-2008 07:15 AM
in expensive paint jobs? LarryJ143 Body - Exterior 4 03-20-2008 07:45 AM
Red paint jobs OK now? Hippie Hotrodders' Lounge 9 04-08-2007 10:37 PM
paint jobs jace Body - Exterior 2 07-25-2004 09:56 PM
