mirrors - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2012, 01:19 PM
Last journal entry: door trim
mirrors
I need some rear view mirrors on my coupe. anybody have a preference as to what works best, peep mirrors, swan style etc. I want to keep it sort of stock looking.
Old 03-01-2012, 04:11 PM
Wiki Edits: 49
I used simple e-bay peep mirrors on my glass bodied coupe. Didn't mount them to the top of the doors though. Modified the mounts so I could bolt them to the door just above the handle. Work just fine there and I think they look pretty good.
Centerline
HotRodsAndHemis.com
"Instructions are just the manufacturers opinion of how it should be put together". - Tim Allen
Old 03-01-2012, 07:13 PM
Cape Cod Bob's Avatar
Love ur coupe. I started with curved peeps on my sedan and went to straight cause I couldn't see past the rear side windows. So, the peeps are available . PM me if interested
ID:	63551   Click image for larger version
Old 03-02-2012, 07:34 AM
peep mirrors
Hey Centerline how did you modify the base? were they originally for a gutter mount? I like the look/ sc
Old 03-02-2012, 12:21 PM
Northstar T's Avatar
Gone sailing
I use a pair of the peep mirrors on my 31 coupe, but when I discovered that you can't twist the head far enough to see behind you, due to the angle of the cab/body in that area, I built an aluminum wedge to go between the cab (top of door) and mirror base. this allows enough adjustment to make them work fine. the alum adaptor is drilled and tapped for two screws that come in from the top edge of the door.
Russ
Old 03-02-2012, 01:15 PM
Wiki Edits: 49
Look HERE towards the bottom of the page.
Centerline
HotRodsAndHemis.com
"If money is what makes cars fast, mine otta be going 400 miles an hour!". - Felix Sabates
Old 03-07-2012, 08:31 AM
Last journal entry: dash mods
I think peep mirrors come in two sizes 3.5'' or 4'', what ever,, I had the small ones and they weren't enough, so I have swan mirrors, They're still in the box some where, they're 4 or 5''. I think a bigger mirror is better.
Old 03-09-2012, 01:31 AM
nasmovtx's Avatar
Last journal entry: Firewall
Mirrors.....
I'm looking for much more of a streamline look and have found only one model of new car mirror that doesn't mount to the corner of the window, but to the body. It's on a Honda fit, 2007 or so. I'll prolly have to demake the mounting base to fit my 37 Terraplane, but being able to use modern components, as well as adding turn signals to your mirrors, er....my mirrors, is a great safety item.
Old 03-09-2012, 07:47 AM
Have you looked at Vision Hot Rod Concepts? If you're in to body color and swoopy, they have some good choices. I'm using them on my 55 PU and am satisfied with the product. Wish they did an electronic control one though.
Modern mirrors - Old Car - What should i use? SprocketMaster Hotrodding Basics 1 01-06-2012 09:05 AM
Corvette Mirrors daveismissing Hotrodding Basics 5 10-15-2011 04:31 PM
Peep Mirrors... BigBlockBabe Hotrodders' Lounge 17 11-16-2007 07:15 AM
What mirrors? yragat Body - Exterior 13 01-19-2007 03:19 PM
Mirrors 52RodTruck Body - Exterior 3 01-07-2007 03:04 PM
