mirros with turn signal - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-15-2009, 10:46 AM
bentwings's Avatar
bentwings
I got a pair of nice outside mirrors with LED lights built in for my birthday. These can be either turn signal or amber parking lights. There are 2 wires in each mirror; one is ground one is power. No instructions came with them. I had to take them apart to figure out how the mirror swivel worked.
Is it possible to have both parking lights and turn signal with this?? I can easily hook up either one off the front lights but both would be better and more kool.
My car has a Painless wiring harness with 1157 bulbs in the rear and whatever the equivalent in the front.
Old 02-15-2009, 11:42 AM
Cape Cod Bob's Avatar
How do you know one wire is ground? If that is the case then you can only run as turn signal or park light, not both.
Have you hooked it up without installing to see how it works?
Old 02-15-2009, 12:07 PM
Joe G's Avatar
Registered user
Anything is possible...
You could use a universal trailer light adapter to combine the front turn signals and park lights for the mirrors.
Universal trailer light adapters are available at any major auto parts store for about $20-30. They are normally used when wiring a vehicle with separate brake and turn signals to have combined brake/turn trailer lamps.
To combine the park/turn lights for the mirrors, you would wire the trailer light adapter module's turn signal inputs into the car's front turn signals, and the module's brake input would be tapped into the car's park light circuit.
That's one way to do it. Hope this helps.
Joe G.
Old 02-15-2009, 11:30 PM
bentwings's Avatar
bentwings
Definitely power -ground as the mirrors are molded plastic, no way to ground thru the housing.
Joe g
Thanks for the clue on the trailer adaptor. I had forgotten all about them. I go right by Northern tool every day so I'll stop in and see their trailer parts selection as it is huge.
I was considering using a diode in each of the supply wires turn and park so I could feed the lamp from 2 sources and not get feedback into each other.
turn signal wiring problemoo Blackhauk90 Electrical 4 09-30-2008 08:20 AM
My Hiboy Needs Turn Signal System Higirl Hotrodding Basics 15 09-01-2006 01:19 PM
50 ford rear turn signal help Edbiosca Electrical 2 07-13-2006 07:45 PM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
Turn signal flasher Seon Electrical 10 12-05-2003 10:34 AM
