misfire - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2007, 02:50 PM
carl01's Avatar
fords rule
misfire it wont idle anymore help
i have a 1985 mustang it had a v6 in it we put a 302 out of a 72 gran torino it ran fine yesterday but i was pushing water out of the exhaust so i put it on tdc then pulled the heads off and put a new head gasket kit it has a crane roller cam and aluminum rockers in when we put it all together and cranked it up i seems like it is out of time or something if anyone can help i would appreciate ie also it will not idle at all
Old 02-25-2007, 07:29 PM
73oldsman's Avatar
For starters, you've done a lot of work on your engine. Is it turning over o.k. but not firing, maybe backfiring? Are you sure you haven't got the distributor stabbed 180 degrees out? We may need more info to help you out here.
Old 02-25-2007, 07:37 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
**IF**, the timing is correct, ( #1 , Compression, TDC, BOTH intake and Exhaust Valves DEAD closed, and the timing marks lined up, with the ROTOR pointing dead on #1 tower) **AND** the firing order IS correct..
My best guess on the limited information provided, is you have some Tight valves, Back them down an 1/8 to a 1/2 turn..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 02-25-2007, 07:40 PM
poncho62's Avatar
Wiki Edits: 5
He says it wont idle....so I figure it runs.........Maybe, ignition wires on wrong.
Misfire at low RPM 65Stanger Engine 9 07-29-2006 02:08 PM
SBC misfire DanoF4i Engine 8 07-24-2006 01:12 PM
Misfire novatech Engine 2 07-12-2006 05:37 PM
Idle misfire ????? motoxracer Electrical 5 03-13-2006 05:49 AM
Cylinder Misfire erimar77 Engine 9 02-03-2005 09:47 PM
