-   General Rodding Tech (http://www.hotrodders.com/forum/general-rodding-tech/)
-   -   Misfire? (http://www.hotrodders.com/forum/misfire-179020.html)
Jeep383 06-06-2010 02:11 PM
Misfire?
Just installed a new cam and lifters into a chevy 383. Upon accelerations, a popping sound from the right headers. Doesn't occur during idle, and doesn't occur at speed, and doesn't occur when reving the engine in neutral or park - only when applying a load. Very conscientious about adjusting valves and following in structions. Spark plug wiring correct. Electrical? Readjust valve lash?
cobalt327 06-07-2010 01:18 PM
The secondary side of the ignition should be checked over closely.
The valve adjustment is always a suspect when this happens, as well.
If the heads are new or have newly machined seats and valves, this may be the culprit. This will sometimes go away w/time. You should do a compression test if the ignition passes muster.
a1supersport 06-07-2010 03:33 PM
Agreed.
Are the springs up to par? How many miles did you have on the original valvetrain?
