Misfire? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2010, 02:11 PM
Misfire?
Just installed a new cam and lifters into a chevy 383. Upon accelerations, a popping sound from the right headers. Doesn't occur during idle, and doesn't occur at speed, and doesn't occur when reving the engine in neutral or park - only when applying a load. Very conscientious about adjusting valves and following in structions. Spark plug wiring correct. Electrical? Readjust valve lash?
Old 06-07-2010, 01:18 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The secondary side of the ignition should be checked over closely.
The valve adjustment is always a suspect when this happens, as well.
If the heads are new or have newly machined seats and valves, this may be the culprit. This will sometimes go away w/time. You should do a compression test if the ignition passes muster.
Old 06-07-2010, 03:33 PM
Agreed.
Are the springs up to par? How many miles did you have on the original valvetrain?
Mysterious misfire sexypizzaman Engine 6 11-17-2009 08:03 PM
false OBD 2 misfire reading??? briansansone Electrical 16 01-01-2009 07:23 PM
Misfire at low RPM 65Stanger Engine 9 07-29-2006 02:08 PM
SBC misfire DanoF4i Engine 8 07-24-2006 01:12 PM
Idle misfire ????? motoxracer Electrical 5 03-13-2006 05:49 AM
