Misfire - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2006, 05:29 PM
Misfire
I have a 1965 nova with the original 230 straight 6. It has low miles on it and runs good except for the misfire I cannot solve. The #2 spark plug keeps fouling out. All the ignition stuff is new; plugs, wires, cap, rotor, as well as the gaskets like the intake manifold, etc. I have run a compression test on the engine and they are all within 2 psi of each other. I have tried spraying carb cleaner around to find a leak and find nothing. It is only the #2 plug. I even tried swapping plugs to see what happened, #2 fouls out. Does anyone have any ideas what might be causing this. I am going insane with this stupid misfire. Thanks for any help in advance.
Old 07-12-2006, 05:33 PM
poncho62's Avatar
Wiki Edits: 5
Is it oil fouled.....?
Burning any oil?
Old 07-12-2006, 05:37 PM
No it is not oil fouled, it is fuel fouled, just like #2 cylinder is running richer then the rest. The car doesn't burn any oil.
Idle misfire ????? motoxracer Electrical 5 03-13-2006 05:49 AM
Cylinder Misfire erimar77 Engine 9 02-03-2005 09:47 PM
misfire ron eckman Engine 2 11-04-2003 06:09 AM
misfire plugs problems 6-71 sbc Engine 5 05-21-2003 09:27 AM
