Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Misfire
Thread: Misfire
Old 04-27-2008, 10:26 AM
Chevyboy454's Avatar
Chevyboy454 Chevyboy454 is offline
HVB454
Sounds like timing for sure, pull off the dis cap and grab a socket and bar, roll the engine until the rotor starts to move then roll it back if you get a delayed movement in you rotor as you turn the crank bolt suspect a bad chain. Did you take the Dis out at any time? Possible you droped her in a tooth off?
