Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Misfire
Thread: Misfire
Old 04-28-2008, 10:21 AM
chevy350_Camd's Avatar
chevy350_Camd chevy350_Camd is offline
VROOOM !!!!!!
Last journal entry: This is the Rough Draft of the V8 Frame
If its not timeing ...
If your timing shows up good after you pulled the distributor and set it to the number 1 cyclinder check your spark and see if its strong and blue if not it could be the plugs after you rule out the plugs check your coil, And if its misfiring is usually a case of retarded timing and I doubt your 34 degrees before is a little bit to slow Sounds Like a weak spark Good Luck
