Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Misfire, but where?
Old 08-01-2012, 02:26 PM
91CamaroDude 91CamaroDude is offline
Originally Posted by bigdog7373 View Post
Also, let the temp climb past 210 if it will. If it doesnt stop by 220 then shut it down because you have a problem.
Its funny you actually mention that. When I wired up my elec fans, I always assumed it was going to push the air into the rad to cool it. Turns out I was wrong and now that I swapped the terminals on the fan and it pulls, I havent seen it get above 210. But that is the reason now why if it gets up to that point yes there is really a problem. Will post an update on the wire change and see if the problem is still there. Thanks for your help!
