Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Misfire, but where?
  #32 (permalink)
Old 11-19-2012, 04:05 PM
91CamaroDude 91CamaroDude is offline
Originally Posted by kc8oye View Post
just a comment on the side conversation on the electric fans.. if your electric fans are running while you are moving, they are doing more harm then good...
once the air speed through the radiator from the vehicle moving, exceeds the air speed generated by the fan blades, they actually begin to restrict air flow!
I have a 160 t-stat, and as long as I'm doing more then 25mph, the engine will run 160 all day long... I have (1) two speed fan, and a smaller single speed fan.. so I use two controllers.. the first controller turns the big fan on 'low' and the small fan on at the same time.. at 190... the 2nd controller brings the big fan up to high speed if I make it to 220F.
With this setup, I can generally sit at a traffic light for a minute or two and the fans won't come on.. and if they do, they turn off almost as soon as I start moving again. (my controllers have temp probes in the fins of the radiator) .. before upgraded to a 110A CS-130 style alternator.. I used to have voltage issues with two electric fans running at idle. which is what originally prompted me to play around with the fan settings...
then, since I don't' have a/c.. I use the a/c control wire with a toggle switch to force the fans on when I want them.. (like sitting in the staging lanes at the track, and I dont' want the engine at 190F when I'm getting ready to make a pass!)
That would be pretty cool to see a picture of that
But to finalize the question in the first post, I have fixed the entire issue. Once I got an ignition coil, plugged it in and I could tell just by the clean startup and sound at idle that it was done. I got the timing light out and got it timed first, then I started checking all the plug wires and every single one of the didn't miss a beat. As usual thanks for everyone's input. ( but really I'd like to see a diagram/picture of how you have your fans setup.)
