I have a stock 350 carbed motor /w t350. For a while now Iv had a miss after it has warmed up. Timing is probably around 16* and locks out at 35*. Its very odd because, if I retard the timing anywhere passed that I have a bad hesitation if I romp on it until about 4k rpms and then it smooths out. However, if I retard the timing to around 12*, after its warm i wont have a miss at idle. Iv re adjusted the valves, removed the floats from the carb n cleaned 'em out with the jets and secondaries, checked for vacuum leaks, it has new plugs n wires gapped correctly. Im not sure if its in the dizzy or where else to look.
It's manifold. That's what I thought before but if I give it a lower timing at idle* it has a really bad miss or stumble until it reaches a certain rpm that's what cunfuses me the most
I mentioned before that I had manifold vacuum, however that was a lie. Im not sure why I assumed it was manifold, but after looking around at other forums it is indeed ported. Rookie mistake.
If I increase the Idle RPM to right around 1100 rpms, the miss goes away. It can be first started for the day, or warmed up in this hellacious weather we have all been having, and the miss goes away.
Would there possibly be a leak in the vacuum canister or somewhere internally in the dizzy that is causing my
idle issue? Or once again is that wishful thinking?
The reason why I mention that is because this time last year is when the swap took place. I was limited to the amount of daylight after work plus the heat. No garage accesible, and hood was removed. PLUS my dizzy cap wasnt on until I was really getting ******* done. Why it wasnt on is beyond me. But it was exposed to the elements of heat and some rain. So there had to be some water that got underneath my cap - how long it was in there is unknown.
Try this. Find out what cylinder has the misfire. Move every wire on the dizzy one forward and follow what terminal goes to which cylinder. Then move the plug from the original problem cylinder to a different cylinder than what the terminal is. Then move the wire to a different cylinder also. An example would be if the misfire was on cyl 5, the terminal would change to 7, wire could go to 3 and plug to 8.
Now, once you have done that, run the engine, (remeber to set you timing right), amd find the misfire. If it followed the dizzy, then that's your problem, or if it followed the plug, or wire, etc..
Well I have replaced plugs and wires and it still has a miss when its warm. But I went out and let it run for a minute or two to see if I could find a dead cylinder with a bottle of water and every single one were sizzling just as much as the other. Now there's a little exhaust leak just after the collectors because I made it out of straight pipe so its not perfect. Would that give me the miss or stumble after its warmed up?
No.
Get a timing light and try it on each wire until you find the inconsistant/ not existant spark.
Once you find it do what I said except without moving plugs and wires. Just the dizzy. If it follows the terminal just replace the whole distributor, not worth messing with imo.
Okay I clearly had no idea what you were trying to explain in the first response, however I think I understand it a little bit more. I have a timing light, and since I was reading your posts last night I figured what better time to see if I can find a bad wire than at night because I had no idea where to track down the bad cylinder. Tracked it down to cyl #7's wire. (pretty sure just the wire cuz when I was removing the wire from the terminal I didnt think to shut the car off and the terminal shocked the piss out of my finger when removing it haha) I swapped #'s 5 and 7 on the terminal and the plugs, and the inconsistant and lack of spark seemed to follow the wire. Now I have yet to continue with your recomendation because upon figuring out which wire was missing, with the long constant idle it randomly shut off on me. And I could tell that my starter was getting heat soaked because after I turned it off to swap out 5&7 when I went to start it up it at first felt like a weak battery but after it started cranking full rotations it would fire up. It was just the first point of starting.
But Im wondering if I should even go any further in trying to figure out which part of the dizzy or not because this is what has happened before with the little miss iv always had; I would drive it a good distance in this 95+ degree heat, it got to around 210 and had a bad stumble and randomly shut off at a light until I let it cool down. But the temp last night never got above 185..not once. And randomly shut off. There was plenty of fuel in the filter right before the carb, but did not look into the bowl to see if it was boiling.
Yep sounds like a bad wire. Do you have an old set laying around? Just swap the bad one out with one from another set and see what happens. Hopefully it will be gone, but if not then you'll have to check the dizzy. I'll try to explain it better if you end up needing to go that route.
210 isnt overheating for an sbc. What carb do you have? Edelbrocks have been known to cause the fuel to get too hot and spill into the intake. This usually happens when you have a low rise intake and the carb mounted directly to it. Basically it floods the engine out at idle. Can also happen right after shutting it off, makimg it a pain to start.
Another thing to look at is that your advance may be getting stuck, which would cause your hard start you exoerienced. Basically your timimg is too far advanced and is working against the starter.
I know 210 isnt over heating but it has a steady climb to that point and I will not let it get over that because of fear of premature damage to the motor. Just me
That also does sound like it could be a symptom because when I first assembled and tried to start it, I had my crank and cam gears 180* out and it gave me that Pffff wubba wubba wubba kinda sound like the timing would be working against the starter. Could the advance get stuck after warm up? or would it do it randomly? Only reason why i ask because unless iv been driving it around and its warm it will never do that to me.
The only way the advance could fet stuck is
A. When you rev it, it will get stuck advanced
B. A bad spring. But it would be impossible to time so that's not an option.
Try the new wire and see whst happens.
Also, let the temp climb past 210 if it will. If it doesnt stop by 220 then shut it down because you have a problem.
Its funny you actually mention that. When I wired up my elec fans, I always assumed it was going to push the air into the rad to cool it. Turns out I was wrong and now that I swapped the terminals on the fan and it pulls, I havent seen it get above 210. But that is the reason now why if it gets up to that point yes there is really a problem. Will post an update on the wire change and see if the problem is still there. Thanks for your help!
What temp are your fans set to come on at? Also what temperature thermostat do you have?
I like a 180* t stat with the fans set to come on at 195 and off at 185. Yea it's a small margin but keeps it at perfect temperature.
I actually have them wired to a toggle switch, with a 160 tstat, and I turn em on a few miles down the road generally around 150 - 160. And with that It keeps it just below 200 on a normal commute to work. If im out toolin around town maybe a little higher but not the 220-230 i used to get before I turned the fan around
Okay got home today and tried a few things. Yes it was too far advanced, the first start of the day was fighting the timing. Retarded it some, boom good as gold, no hard start up. The cooling I will get to after I figure out this miss, only because it's not my dd so I'm not putting hardly any miles on it.
But I got a new wire today, found the irradic wire and switched em. Still no luck, it's probably firing 66% of what everything else is. So I'm deff leaning towards internally in the dizzy. But I would like to try and follow what you had recommended before.
Let me see if I can put it in my way of thinking:
Rotate the wires on the terminal one forward. Line the cap back up with the correct firing order and see if the original miss in cyl 5, would actually have moved to cyl 7 and see if I'm still getting that miss?
Hmm that sounds right. Firing order is 18436572 so you move wire 1 to terminal 8, wire 8 to terminal 4 etc... Basically one forward, which i think u got. Make a mark on the manifold where #1 wire currently is then when you move the wires over, so wire 2 will be on the line so you just turn the dizzy so #1 lines up with it.
I'm trying to say it in the least confusing way i can. It sounded right the way you explained it so go with that.
Right, without actually having it in front of you it's kinda hard to explain but I think i got it. I rotated the wires one forward. Got it timed, still missing on cyl 5. Same as before. It's strange cuz I don't feel it missing as much as the light is showing lol
I took off the cap, and what I assume to be the rotor and all looks good and in tact. The only thing is the metal contacts on what I assume to be the rotor have separated once before like I can take both parts out, and looks like there was once glue on the top metal piece. Is this normal?
The quickest way I know how to check for a miss is to start at No. 1 spark plug wire. Disconnect the wire at the spark plug to see if engine dies any. If it does reconnect and move to the next plug wire. Complete left side first then move to right side. If you pull a wire and engine idle does't change, replace spark plug with a new one. If this does not help ground the spark plug wire to metal. If no arc swap out wire with another to see if you get fire. If still no fire check the under-side of cap. Look for a carbon trail from center black button (coil) to any of the eight terminals or if terminals are corroded. Replace the cap and rotor. If this does not fix the problem check out this: Mallory Ignition 8360M - Mallory Promaster Series Distributors - Overview - SummitRacing.com. Call the order in by phone so you can tell the salesperson that you want the three wire dizzy. It also comes in a two wire model that will need an ignition box. Throw the GM HEI in the thrash.
I checked them last night, not today, but all other wires were working great. I mean its not a huge noticible miss like some modern v6 or even 4 cyl and when they shake real bad, its almost hardly noticible but because I know the car i can feel it and it bugs the crap out of me.
Check out this picture, where I have pointed out theres a red bridge piece almost where i pointed out in blue. Mine is missing. Could this be it?
If suspect, buy a new one. You know it is broke. The metal contact suppose to be molded to the rotor, not removable. To be on the safe side I would replace the cap and rotor, what's $20 not to have the headaches you are having.
You can do the cap and rotor if you want, but they way i think is that if part of it is rigged, you dond know what else is.
Jegs sell a brand new ready to run hei for $79.99. You can find them on ebay even cheaper. Just get a new dizzy. Even if for some reason it doesnt solve the problem it sounds like yours is messed up anyway and i would replace it.
BUT, before you do anything, move the plugs around, you may have a bad plug on that cylinder. Or you can put an old one in it. Whatever you want.
Got a new cap and rotor yesterday, put it on and guess what. No more problems in cylinder #5...it moved to #2. I went to Star Performance and got it for $15 bucks. It deff improved the lack of spark I have been having and has smoothed out the idle, but its still having a lack of spark. The very last part im going to get today for it before just buying a new dizzy is the ignition module. I know it might just be better to get a new dizzy but Im out the 90 bucks for a week or two till I can finally get it in versus just running up to Star and getting it first hand. Immediate gratification. Would anyone else presume that would be the next best bet? Worst comes to worse, i take back the cap n rotor, the module and then just get a new dizzy, so I wont really be out any money. Suggestions?
That sounds like a winner. Glad you can return electrical parts if they don't work! If you have an ignition box get a decent distributor when getting a new one. Most cheap ones are Chinese made and most have alot of problems. I have had the MSD Pro-Billet since 1998 for my 67 Camaro 454 and it's still good.
Sonofab**** theres money out the window. Forgot about the no return policy. Ignition module..fail. Cap and rotor..fail. iv always tried to fix things before I go off n replace 'em. But it looks like its not gonna happen.
I have plenty of parts stores around but star has always done pretty well with the things I need. Oh well you live an you learn I guess.
Next thing I get will be a dizzy and until then if anyone has had this problem and knows a remedy feel to chime in. Thanks for your guys help I do appreciate the feedback.
just a comment on the side conversation on the electric fans.. if your electric fans are running while you are moving, they are doing more harm then good...
once the air speed through the radiator from the vehicle moving, exceeds the air speed generated by the fan blades, they actually begin to restrict air flow!
I have a 160 t-stat, and as long as I'm doing more then 25mph, the engine will run 160 all day long... I have (1) two speed fan, and a smaller single speed fan.. so I use two controllers.. the first controller turns the big fan on 'low' and the small fan on at the same time.. at 190... the 2nd controller brings the big fan up to high speed if I make it to 220F.
With this setup, I can generally sit at a traffic light for a minute or two and the fans won't come on.. and if they do, they turn off almost as soon as I start moving again. (my controllers have temp probes in the fins of the radiator) .. before upgraded to a 110A CS-130 style alternator.. I used to have voltage issues with two electric fans running at idle. which is what originally prompted me to play around with the fan settings...
then, since I don't' have a/c.. I use the a/c control wire with a toggle switch to force the fans on when I want them.. (like sitting in the staging lanes at the track, and I dont' want the engine at 190F when I'm getting ready to make a pass!)
That would be pretty cool to see a picture of that
But to finalize the question in the first post, I have fixed the entire issue. Once I got an ignition coil, plugged it in and I could tell just by the clean startup and sound at idle that it was done. I got the timing light out and got it timed first, then I started checking all the plug wires and every single one of the didn't miss a beat. As usual thanks for everyone's input. ( but really I'd like to see a diagram/picture of how you have your fans setup.)
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
