Mismatched Main Caps - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2007, 08:19 PM
Hey guys I am in the steps of assembling my rotating assembly for my 383 to check clearances and I have stumbled upon a problem. I took off all the caps from the block to have them cleaned and install the bearings in them and now I am unsure of the order of two of them. I am kicking myself now because I should have clearly marked the caps before removing them but I do not even know if they were on the block in the correct positions when I acquired it. I know where the front and rear cap go (obvious) but the middle 3 are all identical and they are stamped. One of them has a "1" stamped on it but for some reason the other 2 both have the number "2" stamped on them. Do you guys know of any other way to determine which cap goes where and what would the numbers mean, I'm assuming the cap marked "1" means closest to the front of the block
Any and all help would be great because I would not want to mate the caps wit the wrong surface on the block.
Thanks again guys,
Keith
Old 02-05-2007, 08:29 PM
Wiki Edits: 31
they don't have arrows? you can just torque them down, check the clearences with a plastigage, until each and every one looks right, or pay a machine shop to do the same thing
Old 02-05-2007, 08:30 PM
BOBCRMAN@aol.com's Avatar
If you have a good eye. Look at the parting lines of the caps and match the tooling/scratch marks in the bores up with those on the block. I have matched up dozens of blocks this way. The marks tend to be very individual to each cap/block combination.
Old 02-05-2007, 08:33 PM
grandpaws 57's Avatar
"Don't need no V/8"-grandpaw
Opps
I think thats what I would,life teaches us these little lessons!
Old 02-05-2007, 08:36 PM
DeathRattle's Avatar
Some Punk Kid
I did the same thing with my engine. Had them stacked up I thought they would go undisturbed. Wrong. When I had it machined and tanked the shop put all back in where they are supposed to be (maybe, I hope).
Old 02-05-2007, 08:47 PM
Thanks for the fast help guys, I think I will do do what you recommended and check the parting lines for the cap and block bore.
P.S.- yes all the caps do have arrows but this just tells which direction to place them, not what order.
454 Main Caps - 2 or 4 bolt question leejoy Engine 4 02-01-2007 09:13 PM
400ci SBC missing 4-bolt main caps? wayfast77 Engine 6 12-05-2005 10:47 AM
SBC Block Questions Mustangsaly Engine 14 06-23-2005 11:14 AM
bbc,sbc main caps torque and thrsut bearing abe Engine 3 05-29-2004 08:23 PM
Main caps... questions blndweasel Engine 12 05-18-2004 07:45 AM
