Miss-Firing HEI - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2008, 03:12 PM
70bird's Avatar
Smile if you know Jesus
Last journal entry: Waiting for a tranny
Miss-Firing HEI
Here's how it happened:
We were hot rodding around town Friday night. Driving the cars pretty hard. We had made a couple WOT jaunts. Eventually my buddies 67 Camaro started acting up. He went to open it up, I heard it start to stumble, then it started back-firing all over the place (out the tale pipe).
The car will idle and rev fine, but as soon as you put any load on it, it starts to back fire and will die. He replaced the module (GM HEI). Initially he thought it fixed the problem. The car was back to normal. However after about 20 minutes of driving the same problem arose. So then he replaced the coil. Same song. After about 20 minutes of driving the ignition will missfire under ANY load.
So what's next? Any ideas?
Will the magnetic pickup cause a problem such as this?
How about the little silver capacitor/canister looking thing that is connected to the module wiring?
Old 10-20-2008, 05:14 PM
was any dielectric grease put in between the module and the distributor?
Old 10-20-2008, 05:51 PM
70bird's Avatar
Yes.........
Old 10-20-2008, 06:00 PM
is the advance still working?
Old 10-20-2008, 06:36 PM
70bird's Avatar
I'll have him take a look at that tonight. I gave him an old, working one I had laying around for him to use as reference/parts.
Old 10-20-2008, 07:00 PM
T-bucket23's Avatar
Wiki Edits: 26
Check the button under the coil for wear and arround it for carbon tracking. This is a common issue. If it is questionable at all change the cap and button with a quality cap. A new cap will usuall come with the button and rubber washer/insulator. You may also want to check to be sure you have full battery voltage at teh b+ terminal on the cap.
Chet
Old 10-20-2008, 07:14 PM
70bird,
Have him check the spark plug wires.
Scholman
Please HELP 98 Vortec engine miss Rescurat Engine 17 06-01-2006 03:39 AM
Cross Fire Hei Firing order Turkey Electrical 5 04-25-2004 06:52 PM
HEI help...before I go crazy EricTopless68 Camaro Engine 13 09-29-2003 09:08 AM
Dead miss MHenricks Engine 7 02-08-2003 06:42 AM
Miss Firing Chevy FoMoCo62 Engine 7 12-05-2002 01:59 AM
